View Poll Results: Whatís the most important thing to you?
Lowest possible cost 3 23.08%
Make it as small and light as possible 6 46.15%
Battery longevity is very important 3 23.08%
Highest power possible 3 23.08%
Highest RPM possible 2 15.38%
Only use through hole construction 2 15.38%
No winding of transformers 4 30.77%
Group buy of components including boards 0 0%
Group buy of boards only 1 7.69%
Iíd rather buy a kit with everything in it 0 0%
I want to buy a pre-built & pre-programmed system 0 0%
I only want to use a 4.8v Ni-MH battery 2 15.38%
I only want to use a 2S battery 1 7.69%
I only want to use a 3S battery 1 7.69%
I want to use a 4.8v battery to 3S battery 5 38.46%
I want to use only off the shelf parts from Digi-Key or Mouser 3 23.08%
I want the Timer board to be separate from the HV board 6 46.15%
I want a combination Timer & HV board 1 7.69%
I want all the options possible using jumpers 3 23.08%
I want a USB connection 2 15.38%
I want a serial connection (DB9) and Iíll use my own USB adapter 3 23.08%
I want a ICSP connection 3 23.08%
I want a premade parts list (BOM) at Digi-Key 2 15.38%
I want a premade project parts list (BOM) at Mouser 1 7.69%
I want 1 design and 1 design only 1 7.69%
I want optional designs to choose from and Ill make the boards myself 8 61.54%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Old Yesterday, 03:47 PM
Joined Jul 2014
Originally Posted by jakestew View Post
> I would really appreciate it if someone would go through the work and proof it.
Took me a bit to find it, but here is a direct link...
http://www.rcgroups.com/forums/showp...&postcount=833
I'll try to take a look, but I'm not the best hardware guy for spotting things off the top of my head. Maybe this will help someone better at this find it easier.
Thanks for your good help, Jake!
Tee One Dee is offline Find More Posts by Tee One Dee
Old Yesterday, 11:56 PM
Joined Dec 2012
Don't like to throw mud in the water after all your good work but you did say..............
C7 is to kill any noise on the chip and as such should be mounted right on the power terminals of the chip.
Same goes for the one on the hall effect.
I imagine you are using some type of double layer, never seen a layout with all the ground connections missing , just looks a bit confusing.
bluejets is offline Find More Posts by bluejets
Old Today, 12:17 AM
Joined Dec 2012
Going through the drawing on #833.
Was the drawing on the left used to make the pc board on the right?
If so, then there are a few errors with capacitor and resistor numbering.
Discussion CD Ignition lead and fixed plug .... solentlife Engines 10 Feb 18, 2014 12:03 PM
For Sale NIB 52cc Gas engine w/CD-Ignition 3.2kw kukntra Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 23, 2012 09:10 AM
Discussion Best open source autopilot vs commercial solution syncra Multirotor Talk 0 Apr 12, 2012 02:35 PM
Discussion Any Open Source / CC CAD Files for gliders? DrFragnasty Composites Fabrication 8 Apr 09, 2012 06:36 AM
Discussion I'm designing an open source quad frame. Inclusions anyone? Physics_Dude Multirotor Talk 3 Mar 11, 2012 01:22 PM
