Old Sep 08, 2014, 08:12 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
1/2A Texaco Baby Bombshell
Hi friends!
I am building a baby bombshell with balsa! I reduced the plans and the wingspan is 86cm and the balsa weight until now is 70gr. IŽll use a 049 cox motor on it with throttle.
049 RC Bomber - Custom Cox .049 Model Engine with RC Throttle Radio Control.
The reason I choose this is that it has throttle control. I will use to cover Balsaloc and Litespan
The Specification:
3 cox micro servos 6gr
1oz Cox gas tank
Cox 049 5x3 prop
Today I covered the firewall and the front of the fuselage with a mix of 1/1 epoxy 15min and alcohol to seal the balsa against the fuel from motor.
I would you like you could tell what you think about my construction, send me any tips and ideas for my building process once I have not so much experience in balsa and fuel motors building
Thank you so much,
Luis
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Sep 08, 2014, 08:21 PM
~SnApRoLl is offline
Find More Posts by ~SnApRoLl
Team Fearless
~SnApRoLl's Avatar
United States, MD, Piney Point
Joined Mar 2005
Sweet plane!
Do you have a link for the plans?
Shawn
~SnApRoLl is offline Find More Posts by ~SnApRoLl
Old Sep 08, 2014, 09:58 PM
Andrew0820 is offline
Find More Posts by Andrew0820
Western KY
Joined Sep 2003
Originally Posted by ~SnApRoLl View Post
Sweet plane!
Shawn
Here it is:
Andrew0820 is offline Find More Posts by Andrew0820
Old Sep 09, 2014, 12:48 PM
gettinout is online now
Find More Posts by gettinout
Joined Jan 2004
Looking very good Luis. For little balsa experience, it looks fine. I don't know if it's the camera lens or not, but it looks like a little misalignment in the tail surfaces. But if so, it's not enough to worry about, your rudder will cancel out the alignment. The lens on my camera isn't made for close up work, so it always makes my pictures look like things are misaligned.
Mark
gettinout is online now Find More Posts by gettinout
Old Sep 09, 2014, 01:47 PM
MiZer1981 is online now
Find More Posts by MiZer1981
United States, WA, Mt Vernon
Joined Jun 2014
Looks awesome!
MiZer1981 is online now Find More Posts by MiZer1981
Old Sep 09, 2014, 04:52 PM
Team Fearless
~SnApRoLl's Avatar
Joined Mar 2005
Originally Posted by Andrew0820 View Post
Here it is:
Thanks Andrew.
Shawn
Old Sep 09, 2014, 06:41 PM
Joined Apr 2005
The tail is not glued in the fuselage yet, I just put them together and itŽs holded in place with clear packing tape to see it "ready". First IŽll cover the tail with litespan and then glue it in place, also for the rudder.
One problem I saw is the bad access to reach the eletronics: servos, speed control and the gas tank. Will be difficult to access from the upside, where the
wing will stay. I was thinking about making a door, right under the firewall, to help
any nedeed maintenance...
The other question is about the throttle: I think IŽll have to instal this servo near the cox 049, but I canŽt work so much now until the parts arrives to me
Thanks for your help!
Mark
Old Sep 09, 2014, 06:44 PM
Joined Apr 2005
Will you build one also?
Thanks for the kind words
Sweet plane!
Shawn
Joined Apr 2005
Tks!!!
Originally Posted by MiZer1981 View Post
Looks awesome!
Old Sep 09, 2014, 06:47 PM
Joined Apr 2005
For the "painting scheme" IŽll do something like this picture. But about the Buzzard pic, IŽm still in doubt
Old Sep 09, 2014, 06:50 PM
Joined Apr 2005
buzz
Old Sep 09, 2014, 07:11 PM
Team Fearless
~SnApRoLl's Avatar
Joined Mar 2005
I'd like to after I get to the next 2 projects. The first I need to get started on is an .09 size Stick with quad flaps and the 2nd one is going to be a .049 sized Playboy Sr. with rudder, elevator and throttle. I am going to use one of my COX Black Widow's with one my old Ace R/C reed valve throttle kits.
Shawn
Old Sep 14, 2014, 08:39 PM
Joined Apr 2005
Hi,
My cox has already the throttle command, as you can see in the picture. I also bought 1oz gas tank that must give me six minutes of flight
Shawn
Old Sep 14, 2014, 09:39 PM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
You can use the master drawing and draw in a bomb shape you like
Amp Abuser is online now Find More Posts by Amp Abuser
Old Sep 15, 2014, 12:44 AM
Team Fearless
~SnApRoLl's Avatar
Joined Mar 2005
Hi,
Those R/C Sure Start's are nice. And that 1 oz. tank should give you plenty of run time.
Shawn
Build Log Frank Zaic 1/2A Texaco Miss America roversgonemad Balsa Builders 17 Apr 03, 2015 01:57 AM
Discussion 1/2a Texaco... jorno67 1/2A Planes 13 Sep 08, 2014 11:20 AM
Build Log 1/2A Texaco Baby Bombshell Luis_Claudio Vintage & Old-Timer Designs 8 Sep 05, 2014 02:49 AM
Sold 1/2a texaco baby bombshell kit nib strangerb43 Aircraft - Fuel - Airplanes (FS/W) 2 Feb 04, 2011 08:42 PM
Gallery 1/2A Baby Bombshell Chris Jenkins Vintage & Old-Timer Designs 19 Jan 11, 2010 06:58 PM
