Old Mar 17, 2009, 05:31 PM
grnbrg is offline
Find More Posts by grnbrg
Still a n00b.
grnbrg's Avatar
Winnipeg, Canada
Mini-HowTo
LP5DSM (Blade CX2 tx) adapter for USB sim cable -- Wiring diagram.
While I don't have a Blade CX2, or the transmitter for it (LP5DSM), I have seen many posts asking if it can be used to control a simulator, and many other posts detailing the problems people have had doing so, and a few posts explaining what needs to be done. And almost no pictures.
So I got tired of searching for a simple explanation of how to make an adapter, and made one myself.
The problem with the trainer port on the LP5DSM is that if you plug a mono 3.5mm plug into it, it short circuits the battery in the transmitter. In technical, electrical terms, this is what is known as a Bad Thing. Since most, if not all of the inexpensive USB adapters that let you use a transmitter to control a sim end in a mono plug, this is a problem.
Fortunately, it is a problem that is easily solved with $10 in parts from Radio Shack, or perhaps less, if you have an old headphone extension cord lying around... You need a 3.5mm headphone socket, and a 3.5mm stereo plug, and a short length of 2 conductor wire...
Simply connect the tip contact from the socket to the tip contact of plug, and the base contact to the base of the plug. The middle "ring" contact of the plug should not be connected to anything. A fancy diagram:
Hope that helps.
grnbrg.
grnbrg is offline Find More Posts by grnbrg
Old Nov 20, 2009, 01:16 PM
wrinkleydms is offline
Find More Posts by wrinkleydms
Joined Nov 2009
Hi, thanks for the info re plug change, which won't blow the TX up, but will it work on a heli?
There have been a number of posts which make me doubt it.
cheers David
wrinkleydms is offline Find More Posts by wrinkleydms
Old Jul 17, 2015, 11:42 AM
yakky is online now
Find More Posts by yakky
Joined Mar 2015
Man, I wish I would have read about this before I let the magic smoke out of my LP6DSM. Time to warm up the soldering iron.
yakky is online now Find More Posts by yakky
Cool Blade CX2 Tx used for micro leadfeather Scratchbuilt Indoor and Micro Models 10 Apr 06, 2008 02:32 PM
Help! DIY sim cable for Blade CX2 tx and FMS MNcowboy Coaxial Helicopters 2 Oct 26, 2007 03:30 PM
Sold USB SIM cable for Blade CP, Like New TJRIDE Aircraft - General - Miscellaneous (FS/W) 0 Jan 03, 2006 12:13 PM
FS: USB Sim Cable for Hitec / Futaba johnreilly Aircraft - General - Radio Equipment (FS/W) 0 Apr 26, 2005 09:57 PM
WTB: USB Sim Cable for Futaba 9C JoeBob1984 Aircraft - Electric - Airplanes (FS/W) 1 Jan 12, 2005 10:40 PM
