Old Yesterday, 08:47 AM
Joined Mar 2013
Hitech HS -82MG servo problem
Hi guy's. ...
I got a PA Addiction X and trying to setup the jr 9303 helicopter radio.
I can't get the servo arms on hitech HS HS-82MG servos to be at 90 degrees mechanically. I use the subtrim and takes between 50 to 70% to get it to be 90 degrees. I know it's too much subtrim.
Please help me out in get this done.
I really appreciated
Rohan
rohama2013 is offline Find More Posts by rohama2013
Old Yesterday, 08:52 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Set subtrim at zero. Remove servo arm from servo. Install at 90 deg.
davidmc36 is online now Find More Posts by davidmc36
Old Yesterday, 11:28 AM
Joined Mar 2013
Hi,
I tried that also to get 90 but it won't do it. It sit little bit off and when I do the subtrim I have put between 50 to 70% in order to get 90...?
Old Yesterday, 11:49 AM
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
As long as you're not running the end points out to 150/150 it will be fine. Just make sure the servo moves the full range of the stick throw.
barracudahockey is online now Find More Posts by barracudahockey
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Do you have any other arms with the servo? Some arms have the splines set just a few degrees or fractions different than others in relation to the arm.
Why do you feel that is too much subtrim anyway? If it gets the arm to center you should still have all your normal trim and normal travel available.
http://www.rcgroups.com/forums/showthread.php?t=927634
Old Yesterday, 11:55 AM
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Originally Posted by rohama2013 View Post
Hi,
Which is normal with most Hitec servos. They use 24 teeth on the spline so even if you have a servo horn with 4 arms no matter how you turn it at 90 or 180 it will always be off by the same amount. For this reason I prefer Futaba servos which use a 25-tooth spline on their servos so by using a 4-arm servo horn the maximum offset will be 1.8. Using a 6-arm horn gives max offset of only 1.2.
With the Hitec servo you may want to use the disk and drill your own hole exactly where you want it.
Ivan
ivanc is offline Find More Posts by ivanc
Old Yesterday, 02:13 PM
Joined Mar 2013
Thank you guy's... now I got it..
I'll try it and give you the feed back.
Thanks once again
Rohan
Old Yesterday, 02:29 PM
Joined Mar 2013
David,
There were three different horns came with the servo one disk, one two sided and a four sided. I tried two of them except the disk. It's not working.
Thanks for the link I will try the way he explains and see.
Old Yesterday, 02:32 PM
Joined Mar 2013
Ivan,
You from round rock near Austin... I'm from Dallas but I go through Austin all the time on my way to San Antonio....
Old Yesterday, 06:38 PM
The ground is the limit!
spooky_0325's Avatar
United Kingdom, Cannock
Joined Dec 2012
I had the same problem. Now I have a Taranis I can centre the servo in the servo page.
Happy days!
spooky_0325 is offline Find More Posts by spooky_0325
For Sale Hitec servos 2x hs- 82mg 2x hs-85mg rayd421 Aircraft - General - Radio Equipment (FS/W) 0 Oct 12, 2014 04:06 PM
Sold 3 hs- 81 and 3 hs-82mg servos C-ME-FLY Aircraft - General - Radio Equipment (FS/W) 2 Oct 04, 2014 02:57 PM
For Sale Hitech servos hs 50,65mg, 82mg ED3 Aircraft - General - Radio Equipment (FS/W) 4 Nov 08, 2009 01:20 PM
Question Hitech HS-82mg servo question Wingwrecker Flying Wings 6 Apr 13, 2008 12:03 AM
