Old Mar 24, 2015, 01:16 AM
Tug Hercules Fireman
Tug Hercules's Avatar
Canada, AB, Medicine Hat
Joined Mar 2008
Plank & Frame - Tug Hull
I am in the final planning stages to finally start my 1st Plank & Frame Tug Hull.
My Tug will be 44-1/2" overall.
What are most folks using for frame thickness; 1/8", 3/16" or 1/4" material, for this size of hull??
Balsa, Basswood or other??
Thank You.
Tug Hercules
Fireman Rick
Tug Hercules is offline Find More Posts by Tug Hercules
Old Mar 24, 2015, 02:43 AM
mr_impervious's Avatar
Detroit Metro, MI, USA
Joined Dec 2007
For my 36" scratchbuilt tug, I used 3/16" 2'x4' luan plywood for the frames and keel. Cheap at Home Depot. Just mind the splinters.
1/8" x 1/2" x 36" Balsa Strips for the planking (with lots of Windex for the curves). Balsa is easier to work with. A little thick, but you're going to need to sand anyways. Wider strips, so a little less work. You're making a big boat.
Finally, Balsa blocks for the bow and stern. Sand to shape of the frames. The balsa strips won't want to bend that severely in those areas.
This worked for me. Hope it helps
mr_impervious is online now Find More Posts by mr_impervious
Old Mar 24, 2015, 07:47 AM
Deckineer at large
nova55's Avatar
New York
Joined Sep 2007
What did you use for glue to attach the planking?
nova55 is offline Find More Posts by nova55
Old Mar 24, 2015, 11:29 PM
Joined Dec 2007
I use Zap-A-Gap Medium CA+ glue with accelerator to speed things up. Then Z-Poxy finishing resin on the inside (by itself) and outside (with fiberglass).
Old Mar 25, 2015, 04:17 AM
Nickel Belter
ZZ56's Avatar
Canada, MB, Winnipeg
Joined Jun 2009
I used Baltic or Russian birch plywood for my frames, 6mm thickness (but it's sold as 1/4 inch, so be careful) and roughly 1/8th inch planks cut from clear pine.
ZZ56 is offline Find More Posts by ZZ56
Old Mar 25, 2015, 04:44 AM
Auckland New Zealand
Joined Sep 2010
I used 3/16 ply for frames and keel and 3/32 x 3/8 clear pine (ripped from 4" x 3/8) planking. I used a pressure steamer (pic 1 ) to soften the planks and gorilla glue as adhesive. Balsa blocks for bow and stern.
This for a 23" model of the Polish harbour tug KLIMEK
So 1/4" ply for frames should be ok, even 3/8".
KIWINB is offline Find More Posts by KIWINB
Old Mar 25, 2015, 07:39 AM
Tim B.'s Avatar
Oakland Ca.
Joined Aug 2009
That's a Nice model you got there ....
Tim B. is offline Find More Posts by Tim B.
Found Lord Nelson Victory Tug FIBERGLASS HULL rctugger Boats (FS/W) 7 Jan 27, 2015 10:34 PM
Discussion anyone cut their own hull planking? Dmon96 Scale Boats 17 Dec 24, 2014 07:03 AM
Discussion Hull planking question babblefish Scale Boats 5 Dec 16, 2014 05:38 PM
Discussion brooklyn tug molded from abs hull dnchvs Dock Talk 5 Dec 15, 2014 06:35 PM
Discussion Tug boat hull Bob Platz Dock Talk 11 Oct 06, 2014 08:28 AM
