Old Mar 17, 2015, 04:27 PM
Joined Feb 2007
Mini-Review
Super Dimona
I have had this plane for a while and love it. There are reports of some bad tendencies but I haven't seen any. In fact this plane has exceeded my expectations. That said I have made some changes. 1. The motor mount needed to be flipped to give down thrust. 2. I have put in some washout by reflexing the ailerons up a few mm. 3. Probably most important the stated CG is wrong. The manual states 66mm back from the leading edge but that makes the plane very tail heavy. The correct CG should be 55 or 56 mm.
This plane flies great. In fact I usually fly at 1/4 to 1/2 throttle. I have not seen any bad stall tendencies. On landing I need to chop the trottle and glide it in. It wants to float.
sinowace is online now Find More Posts by sinowace
Old Mar 19, 2015, 11:18 AM
BHCSR ALEX's Avatar
Joined Mar 2014
This is good information!! Thank you for sharing, it's definitely helpful.
-Alex
BHCSR ALEX is offline Find More Posts by BHCSR ALEX
Sold Taft Hobby Super Dimona 95" ARF -- 4 x 4S new LiPos RayDF Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2015 11:43 AM
Discussion HobbyKing Super Dimona Power Glider EPO 2400mm (PNF) xviper Electric Sailplanes 28 Feb 18, 2015 03:50 PM
Discussion Taft Hobby Super Dimona freddy_fo Scale ARF/RTF 38 Feb 04, 2015 10:47 AM
Discussion Hobbyking Super Dimona thrust line mikesan Electric Sailplanes 1 Jan 16, 2015 12:20 PM
Sold Taft Hobby Super Dimona 95" ARF -- 4 x 4S new LiPos RayDF Aircraft - Electric - Airplanes (FS/W) 3 Jan 13, 2015 12:20 PM
