Old Jan 30, 2015, 09:08 PM
grahambb is offline
Find More Posts by grahambb
Quad Virgin
United States, CA, Oakland
Joined Apr 2014
KK21 zero indication.
OK, two steps forward, six more roadblocks! I now have the Hero with all the internals connected. Lemon Rx, KK21 FCS, all power up, RX bound to a Turnigy 9X with the Orange Tx module.
I can power everything up and when I go into Rx test on the KK2.1, I see each channel but stick movement produces nothing - all indicators stay at zero.
Any offers?
Cheers
grahambb is offline Find More Posts by grahambb
Old Jan 30, 2015, 09:49 PM
Oldgazer is offline
Find More Posts by Oldgazer
Oldgazer's Avatar
United States, VA, Richmond
Joined Dec 2013
Try disconnecting the receiver from the KK and connecting one of the ESCs to the battery port for power. Then try testing each output with a servo.
Verify you have the cables from the RX to the KK installed properly. The Signal lead goes towards the LCD display and the ground lead goes towards the edge of the circuit board.
Oldgazer is offline Find More Posts by Oldgazer
Old Jan 31, 2015, 03:15 PM
grahambb is offline
Quad Virgin
Joined Apr 2014
I connected a servo to the Lemon Rx and each channel drives the servo, but not on the expected stick (Either that or the Lemon instruction sheet is incorrect.....) I connected all to relate to the correct stick movement.
However when I connect back to the KK, still nothing. It all checks out until the KK, which seems to see the Rx, but not respond to any stick inputs. I have doublechecked the jumper cable orientation and they are correct. If I reverse one, the KK says 'no signal'.
I'm really scratching my head now........
Discussion Glow igniter indicator larryoakley Engines 3 Sep 22, 2014 11:56 AM
Sold Electronics for 450 quad NTM 2826, 30a esc's KK21.15 Diviner Gregg Aircraft - Electric - Multirotor (FS/W) 1 Aug 21, 2014 10:44 PM
