Old Yesterday, 10:42 AM
Joined Mar 2015
HV esc for motor needed
Greetings!
I Hope I'm posting this in the correct group.
In short I'm working on an automotive project that has been done before with a couple of modifications. I'm working on the electric turbo.
For my application, I'm going to using a high powered brushless motor. The motor is runs at 46 volts at 326 amps. These values are for a short burst (5 seconds or so) with the motor operating at 46 volts at 180 ~ 220 amps regularly.
As you can imagine; I just can't find an ESC that can handle this voltage and amps! I have the alternative to buy a 58 volt @ 258 amps if that helps any.
Please assist!
teknicalissue is offline Find More Posts by teknicalissue
Old Yesterday, 01:04 PM
Austria, Stmk., Graz
Joined Sep 2013
http://www.world-of-heli.de/en/antri...regler-v4.html
Edit: I should add, at this Power Level your ESC will need cooling and you should not look at cheap chinese ESC's. Just not worth its time...
JAyThaRevo is offline Find More Posts by JAyThaRevo
Old Yesterday, 01:21 PM
Condescending Pedant
Joined Aug 2013
You should have no problem using a 56 volt ESC at 46 volts. The voltage rating is a maximum allowed. Generally it is not a good idea to use any electronic component at it's maximum rating.
Mike Dubovsky is offline Find More Posts by Mike Dubovsky
Old Yesterday, 02:37 PM
USA, CA, Huntington Beach
Joined Sep 2004
Try this place http://www.sevcon.com/ac-controllers/gen4%E2%84%A2.aspx
shadow sst is offline Find More Posts by shadow sst
Old Yesterday, 07:41 PM
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
kontronic make a 200 amp (14s)58 v speed control as do others , guys flying f5b in the past were running 125 amp speed controls at 450 amps for very short bursts , you might be able to get away with the kontronic , I would run a cooling fan on it , you might try contacting Jim Drew at xps , at one point he was planning on making a 20s speed control , don't know if he has any but might be worth a try , good luck ...
Dennis Everett is online now Find More Posts by Dennis Everett
Old Today, 11:26 AM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
You can buy 18S-24S controllers from Flier Model. They opted to sell to the public directly instead of using us a dealer.
JimDrew is online now Find More Posts by JimDrew
Discussion Need motor / esc for Kyosho Scorpion 2014 Rsmith0399 Electric Power Cars 28 Feb 10, 2015 09:29 PM
Discussion need help finding 1/8 scale motor/esc for summit JasonEngleman Hot Online Deals 1 Jan 15, 2015 05:13 AM
For Sale Complete power set up for 25% plane (Tacon motor, HV 100A esc, CC 20A BEC Pro) badkarma Aircraft - Electric - Power Systems (FS/W) 3 Jul 18, 2014 11:21 AM
For Sale Complete power set up for 25% (30cc) plane (Tacon motor, HV esc, CC 20A BEC Pro) badkarma Aircraft - Electric - Power Systems (FS/W) 3 Dec 23, 2013 02:19 PM
Sold Hobbywing 100A HV ESC, 30A esc's couple motors planebldr Aircraft - Electric - Power Systems (FS/W) 0 Oct 21, 2013 07:31 AM
