Old Aug 11, 2015, 09:35 AM
fpvbird is offline
Find More Posts by fpvbird
Joined Jan 2009
Frysky TFR8SB massive drop outs in urban area
Hi!
I am using a original Futaba Receiver for my Multirotor and i have full range with long antennas (3km) On the same multirotor
I use the same long antennas for my Gimbal Receiver Frysky TFR8SB and also have same range when doing a range test in clear country.
If i fly in more urban areas i had massive drop outs (failsafe) from the Frysky Reiceiver while Futaba reiceiver is just working fine.
Failsafe kicks in whithin a Distance of under 50Meter in repeatable flying spots.
Doing another Range Tests in Clear Area Range is good again.
Is there a quality problem with the Frysky Reiceiver?
fpvbird is offline Find More Posts by fpvbird
Old Aug 11, 2015, 09:38 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
Are you using a 14SG and if so was it updated to rev. 5? If so it introduced LBT which makes the FrSky FASST compatible receivers no longer fully compatible. This is exacerbated when the 2.4GHz noise floor is raised as in urban areas with many 2.4GHz operating.
You may want to check out the updates to the first post of this thread if you are using a 14SG.
Ivan
ivanc is offline Find More Posts by ivanc
Old Aug 11, 2015, 09:40 AM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
As Ivan says, try updating your RX firmware, this sounds like the EU LBT issue...
http://www.frsky-rc.com/download/ind...id=12&pro_id=0
PS - It's FrSky, not Frysky!
MattyB is offline Find More Posts by MattyB
Old Aug 11, 2015, 09:42 AM
fpvbird is offline
Joined Jan 2009
thank you guys!
i am using
2x futaba 6308 sbt binded with TX SG14 Fasst
1x Frysky TFR8SB binded with TX Futaba FF-10 Fasst
I don't know about any update
Old Aug 11, 2015, 09:48 AM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
Is this FF-10 (10C in most other places) brand new, that was purchased after January 15, 2015 or older? New transmitters must follow the new rules requiring LBT. The 10CG (FF-10) is not upgradable, the 14SG (and not spelled the other way around) is.
Ivan
Old Aug 11, 2015, 09:52 AM
fpvbird is offline
Joined Jan 2009
Using Futaba SG14 with Version 3 !
Buyed FF-10 before 2015!
Is this not safe anymore?
Old Aug 11, 2015, 09:53 AM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
Then you have a bad FrSky receiver.
Ivan
Old Aug 12, 2015, 08:27 AM
fpvbird is offline
Joined Jan 2009
Must be a problem between Futaba FF10 (buyed 3 years ago) and FrSky Receiver. In my opinion its a faulty Receiver as you said and not a LBT Problem.
For Future i will use Futaba T14SG with Version 5 and R7008SB 2.4 GHz FASSTest Receiver for Multirotor Control
And FF-10 with Fasst Reiciver R6308SBT
Hope for no more Dropouts.
Old Aug 12, 2015, 09:29 AM
MattyB is offline
Taranis Tyro...
MattyB's Avatar
Joined Jan 2004
Simple test - bind the FrSky RX to the 14SG and test to see if you have similar issues. If you do, it is 99.99% certain to be an RX issue.
Old Aug 13, 2015, 01:03 AM
fpvbird is offline
Joined Jan 2009
Hi i also did this!
I had the same Dropout between T14SG and FRsky Receiver while i had no problems between FF-10 and Futaba Receiver.
But its very hard to test because its mostly in urban areas in special positions.
Old Aug 20, 2015, 11:29 AM
CapBlack is offline
Find More Posts by CapBlack
Joined Jul 2012
Hi!
the same problem cost me a lot of money, very bad product FRSKY stay away !!!!
minix crash 2 (0 min 51 sec)
CapBlack is offline Find More Posts by CapBlack
Old Aug 20, 2015, 03:12 PM
MattyB is offline
Taranis Tyro...
MattyB's Avatar
Joined Jan 2004
Hi i also did this!
These RXs have a great rep overall - several of my mates swear by them - so it sounds like you have a faulty unit. Return it to your supplier for a swap-out.
Old Aug 21, 2015, 05:11 AM
CapBlack is offline
Joined Jul 2012
It may be a defective unit, but again not to take risks, even if they give me two, as a gift, rather than buy a Futaba not in doubt for $ 20 less
first glich (0 min 44 sec)
Discussion Futaba 8FG + FrySky TFR8SB + CC3D w CleanFlight xNuno Multirotor Electronics 0 Jul 01, 2015 08:49 AM
Sold Massive price drop, great deal on NEW Esky 900+much more! corsair44 Aircraft - Electric - Helis (FS/W) 1 Jun 25, 2015 10:34 AM
Discussion The legalities of flying in urban areas Jovanx Electric Plane Talk 66 Sep 12, 2013 05:50 AM
Question 5.8 in urban areas flyboy321 FPV Talk 9 Mar 25, 2011 09:58 PM
Flying in urban areas. ashdec87 Aerial Photography 17 Nov 07, 2005 03:31 PM
