Old Feb 15, 2015, 05:31 PM
julescrafter is offline
Find More Posts by julescrafter
Scale RC Plane Lover
julescrafter's Avatar
Indonesia, Jakarta
Joined Jul 2013
Build Log
Scale F4U Corsair 1200 mm with Plans
UPDATE :
F4U Corsair 1200 mm Project is complete
you can download the PDF file below
Assembly instructions
This plane will be my 7th design and build RC plane. I made the model with Gmax, a free version of 3DS max and use pepakura designer to unfold the 3D into 2D model. I use mainly polyfoam / depron foam 5-6 mm. Latest progress is the wing, I use hard balsa hardened with CA glue for 2 spars, ribs with foam. I already installed the retract landing gear that I bought from Hobbyking. The plan will be released and shared here and in my site once the plane can fly on the her maiden flight.
Plane specification
- wingspan 1200 mm
- flying weight target 1200 grams
- motor, hobbyking 350 watt 750 kv (durafly mustang 1100 mm motor)
- esc : 35A
- battery : 3S-2200 mAh
- prop 3 blade master airscrew 11x6
- landing gear : 2 retract, fixed but steerable tail wheel
- material : polyfoam/depron 5mm, plywood 2mm, hard balsa 2mm
- glue : hot glue
- coloring : printed paper coating (try new method)
video on landing gear test
Landing Gear Retraction Test on Homemade Corsair (0 min 27 sec)
Jules
julescrafter is offline Find More Posts by julescrafter
Old Feb 18, 2015, 12:49 AM
Joe Valentin is offline
Find More Posts by Joe Valentin
United States, AZ, Yuma
Joined Mar 2014
Looking good!! I'll be following this one.
Joe Valentin is offline Find More Posts by Joe Valentin
Old Feb 18, 2015, 04:41 AM
Indonesia, Jakarta
Joined Jul 2013
Thank you Joe
another progress, rudder and elevator platform. Now all parts are finish and then I need to unfold the fuselage parts and later print them.
Old Feb 18, 2015, 11:10 AM
miss5031 is offline
Find More Posts by miss5031
Joined Nov 2011
So cool. Subscribed and can't wait to see it all come together.
miss5031 is offline Find More Posts by miss5031
Old Feb 18, 2015, 11:12 AM
Robert4613 is offline
Find More Posts by Robert4613
Is it spring yet?
Robert4613's Avatar
United States, UT, Vernal
Joined Nov 2014
I'm in love! I am partial to the F4U Corsair, so much so that I've had my local Staples print me off three different sets of 24" X 36" plans to build out of DTF in the near future. The retractable landing gear is an added bonus. Looking forward to your maiden flight!
Robert4613 is offline Find More Posts by Robert4613
Old Feb 18, 2015, 01:17 PM
Indonesia, Jakarta
Joined Jul 2013
Thank you miss5031 and Robert, corsair is one of my favorite planes. I'll keep posting the progress and surely will make a video of the maiden flight
Jules
Old Feb 18, 2015, 01:41 PM
Is it spring yet?
Robert4613's Avatar
Joined Nov 2014
Looking forward to the progress.
This is my inspiration for me to build a DTF or EPP version.
Old Feb 18, 2015, 01:57 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I'm not sure how you are constructing the Corsair fuselage from the CAD pictures, but I thought I would show the method I now use based on an internal box to support the formers.
The model is a 67" span Dauntless --
eflightray is offline Find More Posts by eflightray
Old Feb 18, 2015, 01:59 PM
Indonesia, Jakarta
Joined Jul 2013
Is that corsair made from balsa? beautiful plane and that cessna is nice too.
Jules
Old Feb 18, 2015, 02:05 PM
Indonesia, Jakarta
Joined Jul 2013
I will build it with the way I build my 1300 PT-17 Stearman. Similar with your method, but with a lot less formers / frames.
Old Feb 18, 2015, 05:44 PM
Is it spring yet?
Robert4613's Avatar
Joined Nov 2014
Jules
Yep, that's an H&M F4U Corsair balsa and plywood ARF. But I'm a bit nervous about flying it, even if I had all of the components for it.
That other plane is an Apprentice S RTF with the AS3X system. Yes, I'm cheating with it, but I am a newbie after all. Sometimes it's also my Mobius platform.
You're giving me some accelerated motivation to begin the build process on my foam Corsair.
Old Feb 22, 2015, 11:16 AM
Indonesia, Jakarta
Joined Jul 2013
I should have been printing the plans and began to build the fuselage this weekend but then I realized my printer run out of ink. Need to buy new one tomorrow, in the meantime i continue detailing parts like missiles and bombs. All parts already drawn into plans, ready for printing. This is a progress pic
Jules
Old Feb 23, 2015, 01:58 AM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
How did you do the gull wing spars? Is it cut from a single piece of balsa or glued from pieces? Is it strong enough to withstand landings? I've been wanting to build a Stuka for a long time now but can't figure out how to do the spars.
slebetman is offline Find More Posts by slebetman
Old Feb 23, 2015, 06:37 AM
Dreamcatcher is offline
Find More Posts by Dreamcatcher
Warbirds Lover
Dreamcatcher's Avatar
South of France
On my 100cm WS Corsair i cut two "W" parts from 3mm plywood and the wing spars was "sandwitched" between these two plywood parts (the external wings was stuck on the W pieces once they was finished).
Dreamcatcher is offline Find More Posts by Dreamcatcher
Old Feb 23, 2015, 06:47 AM
Indonesia, Jakarta
Joined Jul 2013
I cut it from 1 sheet balsa, and then hardened it with CA glue. I use 2 spars front and back. Strong enough for landing? I don't know yet, we'll know it on maiden flight.
I think plywood has more strength, I should use it but too lazy to cut one
Download My 1300 mm Semi-Scale Cessna 185 with plan julescrafter Foamies (Scratchbuilt) 18 Feb 19, 2015 02:11 PM
For Sale Dynaflite Fun scale F4U Corsair Kit titoplane Aircraft - Fuel - Airplanes (FS/W) 4 Oct 29, 2014 07:58 PM
Wanted 36 mm INRUNNER 1200 watts plus with 500 kV Megowcoupe Aircraft - Electric - Power Systems (FS/W) 0 Sep 30, 2014 02:43 PM
Sold 1400 mm FMS F4U Corsair Modified with 3 stage flaps, $240.00 shipped brandonmoon Aircraft - Electric - Airplanes (FS/W) 3 Jul 27, 2012 04:04 PM
