Old Dec 31, 2014, 02:05 PM
sharkman is offline
Find More Posts by sharkman
sharkman
San Diego, Calif.
Joined Jul 2004
Build Log
Sterling Coursair F4U - My First Scratch Build
I've been working on this build for several months and decided to share some of the progress this far. First, I want everyone to know that this is my first scratch build. I've built three other kits, two fly very well and the third needs some serious tweaking.
I started this project by printing out all the parts using the print wood PDF pages and selecting various sections and then printing to scale. I cut out each outline with a very sharp xacto blade and then used glue paste to attach it to the wood thickness including the 1/16 ply. I cut all the parts by hand with the xacto blade except the ply which I used my B&D jig saw and then filed and sanded to correct shape. I had to make up the battery hatch along with the servo location although the plans do show a servo location for the elevator and aileron servos. So, at any rate, here are some pictures of my progress so far.
Thank You,
Respectfully,
sharkman.
sharkman is offline Find More Posts by sharkman
Old Dec 31, 2014, 02:07 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's a few photos so far.
Old Dec 31, 2014, 02:08 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's a few more of the center section.
Old Dec 31, 2014, 02:10 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's the wing panels.
Old Dec 31, 2014, 02:12 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's the rest.
Old Dec 31, 2014, 02:14 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's the aileron's. I cut these from aileron stock and then glue them together to double the thickness to match the wing panels.
Old Dec 31, 2014, 02:18 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's the wheel wells. I haven't figured where to place them exactly yet and how to make up the lost support. Once I do, I'll post some pics.
Old Dec 31, 2014, 02:21 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's some shots of the fuse, battery hatch and motor mount.
Old Dec 31, 2014, 08:24 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's the hatch.
Old Dec 31, 2014, 08:26 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's the center wing sheeted top and bottom middle. This is so I can get the wires through and get the wheel wells installed.
Old Dec 31, 2014, 08:28 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Oops. Sorry. Here are the pics.
Old Dec 31, 2014, 08:29 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Here's the motor mount.
Old Dec 31, 2014, 08:32 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Right now, the motor is a Thunder Tiger and the ESC is a 30 amp unit. Can't remember where I got it, but it came out of my old Corsair.
Old Dec 31, 2014, 09:08 PM
RCAV8R1964 is offline
Find More Posts by RCAV8R1964
Short bursts, Don't waste ammo
RCAV8R1964's Avatar
United States, GA
Joined Feb 2006
I built this kit many years ago. It's a nice kit. Outerzone has the plans if anyone is interested. I am interested to see how the retracts will fit.
RCAV8R1964 is offline Find More Posts by RCAV8R1964
Old Jan 01, 2015, 01:19 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I have this neat old kit but have not attempted to build it for electric RC because of the model's sheeted balsa design, and probable heavy wing loading, which will probably result in a model that must fly and land fast to avoid stalling. Adding retracts will probably make matters worse. If you are using a TT .10, it will likely have adequate power. Try to avoid unnecessary weight in the rear fuselage/tail area and mount stuff foreward to reduce need for nose ballast. Good luck, will watch with interest.
E-Challenged is offline Find More Posts by E-Challenged
Build Log Vickers FB5 "Gunbus" My First Scratch Build hammerd Scale Kit/Scratch Built 188 Today 07:44 PM
Build Log My first large scale scratch build Shadow-D Scale Kit/Scratch Built 22 May 14, 2015 11:44 PM
Discussion My first P-51 Mustang!!! My first scratch build!! Rain1dog Beginner Training Area (Aircraft-Electric) 18 Nov 22, 2014 08:21 AM
Build Log My first sort of Scratch quad build. nafan08 Scratchbuilt Multirotors 15 Nov 15, 2013 07:59 AM
