Old Jul 21, 2014, 11:17 AM
jim51945's Avatar
United States, IL, Lake in the Hills
Joined Jul 2012
Help!
Het 70mm edf
I have a HET 70mm EDF fan unit # 6904, attached to an ARC 28-38-2, 3750kv motor. The ESC is a HP Electronics 80a. I had it installed in a Hobby People Phase 3-16 foam body. All worked well.
I moved the EDF/motor/esc to another jet, and now, when I give it full throttle, the motor goes to a low rpm/idle. She is good until you get past 80-90% power.
Any advice as to what might be the issue??
jim51945 is online now Find More Posts by jim51945
Old Jul 21, 2014, 04:40 PM
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
The outlet diameter of the exhaust nozzle may be too constricted in the new jet. This would cause the amp draw to increase to such a level causing the ESC to partially shut down resulting in the motor to go low rpm/idle.
- If you are using different batteries in the new jet ,they can' handle the amp draw of the motor.
shhhhh! is offline Find More Posts by shhhhh!
For Sale 70mm EDF HET setup with Turnigy 85amp esc f250r71 Aircraft - Electric - Power Systems (FS/W) 1 May 28, 2014 04:15 PM
Sold NIB HET 2W-27, 2W-20 motors and HET 6904 70mm EDF Units The Don Aircraft - Electric - Jets (FS/W) 0 Mar 03, 2014 06:45 AM
For Sale HET 70mm EDF MAKODS Aircraft - Electric - Power Systems (FS/W) 2 Nov 27, 2013 02:57 PM
Sold 70mm Cyclone EDFs 12blade and Alloy Cased HET 6904 >>> Alpha10 Aircraft - Electric - Jets (FS/W) 5 Oct 31, 2013 06:50 PM
Sold HET (High End Technology) 2W-20 70mm EDF $65 MickeyD Aircraft - Electric - Jets (FS/W) 0 Sep 27, 2013 11:23 PM
