Old Aug 06, 2009, 01:07 AM
Registered Drug Free
LunaRendezvous's Avatar
Joined Jan 2009
Parkzone P-51 Gunfighter Modification Thread
Thought it would be good to pool all the mods into one thread, as it evolves Iíll try and update the first post with links to the different mods on other pages. Feel free to add you own mods and advice.
Note: If you are going to post pictures with your mods, please use the attachment function to save people from scrolling and needlessly wasting of their bandwidth.
I wasnít happy with the horizontal stab on my gunfighter, and as Iíll be flying at my local sports field, the last thing I want is for anyone to be injured, as such it will take priority..
For this mod Iíll build a new stab and elevator from Ĺ inch balsa sheet, and hinge it with Dubro standard nylon hinges DUB116 I will also reinforce the two elevator halves with 1/16th 3 ply.
The work so farÖ
...and all finished!
http://www.youtube.com/watch?v=aqG112kGc4c
LunaRendezvous is offline Find More Posts by LunaRendezvous
Old Aug 06, 2009, 02:49 AM
Joined Jan 2009
Reserved.
Old Aug 09, 2009, 05:38 AM
Joined Jan 2009
Battery Strap Mod
Battery Strap Mod
This is a very common and straight forward modification, which not only allows you to use larger batteries but also adjust there position for optimal centre of gravity.
Use a new blade in your hobby knife to cut out the foam from behind the original battery strap, so that there is one continuous slot running from the receiver to the forward compartment. Then glue in a strip or two of Velcro.
Mark and cut 2x 2 1/2inch lengths of K&S 7/64 aluminium tubing, but any small diameter will do. The easiest way to cut it is to place the tube on a beer coaster and then put the blade of your hobby knife on top of the tube and roll it along the coaster.
Then cut two 3 inch lengths of heavy duty fishing line and insert it into the tube. This help stop the tube from kinking when you bend it and generally adds strength. Then go ahead and make the bends with a pair of pliers. Once the bends are done you can trime the line and sharpen the ends of the tube with a file, this will make pushing them into the foam a synch.
Push your newly made staples into the foam where you want the battery to be held, for my set up that was just in front of the hole where the aileron servo leads go. Once you have checked their position you can remove them and fill the holes with epoxy. Run the battery strap under the staples and then put them back in and allow the glue to set.
The last thing that needs to be done is to slice the foam hump off the bottom of the hatch/canopy cover. This can weaken the canopy some as the foam is quite thin in that area, so treat it gentle. If needed reinforce that area with a small piece of silk and epoxy resin.
Mike.
Old Aug 09, 2009, 07:39 AM
The faster the better!
TLMARK's Avatar
Southern England
Joined Jan 2009
Cool post Luna thanks for you tips
TLMARK is online now Find More Posts by TLMARK
Old Aug 15, 2009, 08:34 AM
Joined Jan 2009
Cheers Mark, should have another fix/mod posted on Monday
Mike.
Old Aug 23, 2009, 07:34 PM
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
Thanks for the pictures/mods! I just came home with some 1/4" balsa Friday and was ready to build my own elevator. Your pictures will be a big help. I like the ply reinforcement.
Get out the dust mask!
JimTMich is offline Find More Posts by JimTMich
Old Aug 23, 2009, 11:53 PM
Joined Jun 2009
How did you cut the bottom of the battery tray so cleanly?
Nickbm3 is offline Find More Posts by Nickbm3
Old Aug 24, 2009, 12:00 AM
sKrude up, Rejected!
DogFly.'s Avatar
Joined Jun 2008
Twin Mustang mod:
http://www.rcgroups.com/forums/showthread.php?t=1095175
Sorry Luna,
It is a mod!
DogFly. is offline Find More Posts by DogFly.
Old Aug 24, 2009, 10:48 PM
Joined Jun 2009
Luna- Your Hstab looks awesome, any interest in making more and selling them?
Old Aug 24, 2009, 10:52 PM
Plane Crazy!!!
Ft. Lauderdale, FL
Joined Sep 2006
Anyone who swapped out the stock prop for a Trojan prop did you also have to use the Trojan's collet adapter?
Kilo60 is offline Find More Posts by Kilo60
Old Aug 24, 2009, 11:32 PM
Joined Jan 2009
Nick, to cut the battery slot I used a standard utility knife (see pic) with a fresh blade. Do the vertical cuts first, measure how deep they need to be, and then place a small piece of masking tape on the blade so you know how far down you are cutting. Once you have sliced the foam vertically, go in a slight angle and remove wedges of foam on each side of the battery slot. You will end up with a "W" shape, then remove the tape and extend the knife blade as far as it will go and carefully slice out the middle " ^ " section.
...thanks
Sorry Nick, It takes a few hours to make one so it would not be cost effective, also my time is very limited these days. It really is not that difficult to carve balsa, a sharp knife and a sanding block are the minimum tools required, just remember to always cut away from yourself and fingers (number one rule ! never forget it ), get the lightest wood in the rack and enjoy the experience.
Originally Posted by DogFly.
Twin Mustang mod:
Sorry Luna,
It is a mod!
No worries Dave, The more the merrier! Been keeping an eye on that thread, looks like you're coming along nicely.
I have not tried this myself, but it looks as if it will work, the motor shaft is identical.
Mike.
Old Aug 25, 2009, 12:26 AM
DogFly.'s Avatar
Joined Jun 2008
Mike.
Hi Luna,
Thanks!
Obviously I'm on your thread , but I was thinking once I finish the Twin, I might modify my P-51 into a B or C model!
I like your battery mod, on my plane I'm running a Du-bro 2 1/2" spinner, so with the added nose weight I can put my battery close to the cg.
I'm running 2200 size Lipos.
I also cut my foam similar to yours, and I pulled the stock battery mount and glued it into the new battery area.
Old Aug 25, 2009, 12:44 AM
Joined Jan 2009
Dave, as soon as I receive a couple of servo extensions from HC I'll be moving the Rx back behind the servos in the air scoop, then the lipo can be positioned anywhere along that slot. It will be a cold day in hell when I resort to adding ballast to an airframe to achieve the desired CG.
Mike.
Old Aug 25, 2009, 12:52 AM
DogFly.'s Avatar
Joined Jun 2008
Luna,
I didn't really think of the spinner as ballast! LOL
I didn't want to/couldn't use the stock one!
Old Aug 25, 2009, 01:01 AM
Joined Jan 2009
If you need more weight up front then try the Hyperion P51 aluminium spinner, frigging thing weighs 2oz, looks nice and scale though. I have a couple of the plastic dubro spinners for some of my control line birds, I find they wobble a little too much for my liking, so have replaced them with the great planes spinners with the aluminium backs. Same as the one in my vid of the elevator mod.
Discussion Gunfighter! - The official Parkzone P-51 Mustang BL thread ugly john Electric Warbirds 13460 Jul 21, 2014 11:05 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Discussion ParkZone's P-51 Gunfighter Discussion Thread [NOT the PZ P-51 Complaints Thread] dabesq Electric Warbirds 184 Jan 19, 2010 10:21 AM
Question Release date for the Parkzone P-51 Gunfighter? ugly john Electric Warbirds 41 Jun 27, 2009 02:51 PM
Discussion Ultimate Parkzone P-51 Rebuild/Modification Extremeace Parkflyers 25 Jun 08, 2009 03:00 PM
