Old May 02, 2014, 01:44 PM
Joined May 2014
futaba t9cp problem
hi all i just got my self a futaba t9cp , ive tried 3 diffrent receivers ,r136f ,fp-r138df and the r149dp but none seem to work ie nothing moves when i connect them
dnorthstar is offline Find More Posts by dnorthstar
Old May 02, 2014, 07:53 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
ok I will bite, do you have the transmitter module in the back?
do you have matching frequency receiver?
is your radio on PPM?
has your new radio had the antenna soldered on, I do not remember if it was the 8 or the 9, that had that issue, was a simple soldering of the wire too the antenna!
last but not least are your batteries charged?
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: heli's
Old May 03, 2014, 03:00 AM
Joined May 2014
hi there yes the module n the back is tw-fm 35mhz
the receiver is a futaba r 149dp 9 channel pcm
yes radio is on ppm and fully charged
dont know about the antenna will have to check thanks ..
Old May 03, 2014, 03:22 AM
Joined May 2014
just checked the antenna wire all is fine ive noticed that only 1 light is on on the radio should there not be 2
Old May 03, 2014, 09:45 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
ok! mine when turned on, has both a red light for power! and a green light for RF!
now I have a couple modules, on a couple different channels but they are all 72mhz
do not quote me, but I think if you are running 35mhz, then someone has converted that radio too ground frequency!
unless your receiver in on the same frequency and channel, your not going too get a connection!
Old May 03, 2014, 11:23 AM
Joined May 2014
the rf light is not on so what can i do ?
Old May 03, 2014, 01:58 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
not sure where you got your radio! but as I mentioned, the RF module in the back, should say 72mhz with a channel number on it!
when I pull my RF module out, the green light does not come on!
so I would say you need a new RF module, that match's your receiver!
Old May 03, 2014, 02:34 PM
Joined May 2014
mine has no circles but does say 35mhz and thats it think maybe i should change it
Old May 03, 2014, 03:19 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
http://www.hobbyking.com/hobbyking/s...Module_RX.html
seems the only bad reviews are the one's not using Futaba!
couldn't hurt!
and if you get it working, I highly recommend a 2 cell life transmitter battery! as the 9C is an amp hog!
Old May 04, 2014, 01:15 PM
Denver, CO
Joined Dec 2005
The 72mhz is not used in all countries. I didn't notice him say where he is.
Roto Rob is offline Find More Posts by Roto Rob
For Sale Futaba T9CP w Dragon Link keenan121 FPV Equipment (FS/W) 4 Apr 21, 2014 01:39 PM
Discussion APM 2.5 Failsafe Problems with 35mhz Futaba T9CP zekezero UAV - Unmanned Aerial Vehicles 0 Feb 22, 2014 02:36 PM
Question Orange DIY Module with Futaba T9CP PaulB Radios 1 Nov 03, 2013 09:12 AM
For Sale Futaba FF9 T9CP super + Futaba TM7 2.4 Ghz module raspa Aircraft - General - Radio Equipment (FS/W) 0 Jul 05, 2010 07:57 AM
Discussion Problems calibrating Futaba T9CP in Realflight 4.5 Guncha Simulators 2 May 31, 2010 03:32 AM
