Old Nov 11, 2013, 10:35 PM
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
This is EPO foam. (Extruded Poly Olefin )(sp?) It will tolerate just about any kind of rattle can you want to throw at it. Lacquer, Enamel, Epoxy based paint, Latex, Oil based, you name it. You can and should even wipe it down with acetone before you paint it. If you want the ultimate in paint adhesion, the best process is this:
- Mix wood glue and talcum or baby powder so that it is thick, but not too thick to brush on.
-Brush on a thin coat of this mix, and allow it to dry
-Brush on a second coat of this mix, and allow to dry again
-Lightly sand the dried coating to a smooth finish. If you lay down just the right amount, it will be very smooth
-Go to the autoparts store, and get a can of Adhesion Promotor made by Duplicolor, and lay that down. It is clear and un-noticeable.
-Paint to your hearts content
Note: it is best to only put this primer mix where you want to actually paint. If you are going to paint the entire bird, then you would coat the whole thing. If there is an area that you intend to leave white, your best bet is to leave it bare foam. No sense in adding weight with the primer coat, and then having to shoot more paint with the white.
Note #2: You can spray or brush on just about any type of paint that you like to use. Acrylic does not do so well when brushed on, and should be airbrushed if you want to use acrylic. You can paint the plane with anything without the mixture, but if you lay down a color, and then you try to mask it to lay another color..the masking tape will probably pull it off the foam if you don't use the priming mixture.
-CC
PS I just added the N numbers to my plane. I will post a pic in a few minutes.
Cubcrazy is offline Find More Posts by Cubcrazy
Latest blog entry: Carbon Z Cub Floats are here!!
Old Nov 11, 2013, 10:50 PM
United States, CA, Vallejo
Joined Oct 2013
Thanks for the info
Skyscanr is offline Find More Posts by Skyscanr
Old Nov 11, 2013, 10:53 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
N-number
I made the stencil for it by printing the number from Microsoft Word, then laying it down on a sheet of adhesive back (peel off) paper, and cutting the numbers into the adhesive paper by hand with a #11 Exacto Blade. Then I used this as a stencil-stuck it to the plane, and shot it with the same paint used on the rest of the plane.
-CC
Old Nov 12, 2013, 02:31 AM
mrtibbs's Avatar
United States, PA, Philadelphia
Joined Sep 2013
-CC
Very Very Nice!
mrtibbs is offline Find More Posts by mrtibbs
Old Nov 12, 2013, 02:34 AM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Probably just some stripes on the Fuselage and that will be it. The wing needs a little more color too. Those white wings disappear in the clouds late in the evening.
Old Nov 12, 2013, 09:09 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Video of my second flight.with the SR on 9 Nov 2013. Camera man didn't show in time to capture maiden. This was the guys first attempt at using my camera, so be kind.
As always, watch in HD.
-CC
Dynam SR-22 (3 min 52 sec)
Old Nov 13, 2013, 04:39 PM
Australia, VIC, Bendigo
Joined Jan 2012
cubcrazy..that vid was pretty good for a beginner...Can you remind us again what motor/esc/blade combo you are using..I do like the idea of 1/2 throttle takeoffs..It leaves a lot in reserve...more is better for me.
agedflier is offline Find More Posts by agedflier
Old Nov 13, 2013, 05:16 PM
Joined Jan 2013
Just a few picture of this SR-22 I've added some detail not much.
Atx10 is offline Find More Posts by Atx10
Old Nov 13, 2013, 05:36 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
I am running a 480 Plus from headsup RC out of Ocala Florida. A 40 amp ESC, and a 10x7x3 MAS prop. Their site quotes 33 amps on that combo, but I have been getting more like 26-30 depending on the age of the battery. I run 2650, 2700, and 3000 packs. My timer is set to 12 minutes with these large batteries. It's not a really fast machine, but it's got lots of grunt. I can climb near vertical forever. I run 35 and 40c packs.
Since you are in AUS, I would be on the lookout for a 1000kv 35mm diameter motor rated at 450 watts. I may step up to an 11x7 3 blade, but this 10 feels like the sweet spot for looks and performance.
-CC
Old Nov 26, 2013, 07:42 AM
mrtibbs's Avatar
Joined Sep 2013
Maiden ed my SR Trainer last Saturday...I have a cockpit camera view FPV of the first flight.
SR Trainer Maiden (6 min 5 sec)
Old Nov 28, 2013, 08:53 PM
Joined Jan 2012
mrtibbs...great 1st flight...Pity about that big chunk of foam...lol I think I will try cut mine down a bit and relocate the battery tray as others have done here.
Old Nov 28, 2013, 10:27 PM
mrtibbs's Avatar
Joined Sep 2013
Yeah I cut it away the other day lol...I noticed that when I got it home after the maiden the prop was very loose...I was super sure I glued the heck out of the engine mount....when I opened the nose I found that the X mount (little black screws) were all loose to fall out except for one!...If I was in the air for 3-5 more mins it would have crashed!...I applied loctite to all of them and screwed them back in.
Old Nov 29, 2013, 04:47 PM
Joined Jan 2012
mrtibbs....Have you done any other mods?? batt/landing gear/motor/lights..Mine is still in box. Im like a lot of others..See one you like and buy it before is goes out of stock.
Old Nov 29, 2013, 06:48 PM
mrtibbs's Avatar
Joined Sep 2013
Just the motor upgrade to a Turnigy 1100kv motor is about it ...I did pickup a light kit today from HK for $7.95
Old Nov 30, 2013, 10:01 PM
mike_mike's Avatar
Joined Feb 2013
Hello guys! I just grabbed mine a few days ago and flew it for the first time! Flies great but looks really plain so i will be adding a Red bull paint scheme to it!
mike_mike is offline Find More Posts by mike_mike
Discussion telemaster sr ARF jrplane Electric Plane Talk 1 Nov 27, 2010 09:43 PM
Discussion Dynam Sky Trainer 4CH RTF NJRC Beginner Training Area (Aircraft-Electric) 10 Nov 18, 2010 08:45 PM
For Sale Aero Sprint Elec. ARF Trainer 50" W/S puplover Aircraft - Electric - Airplanes (FS/W) 0 Nov 15, 2010 04:15 PM
Sold Aero Sprint ARF trainer by Parma puplover Aircraft - Fuel - Airplanes (FS/W) 0 Nov 13, 2010 02:47 PM
For Sale MM Special High-Wing Trainer ARF Kit AJ750 Aircraft - Electric - Airplanes (FS/W) 4 Oct 29, 2010 10:36 PM
