Old Aug 30, 2014, 09:19 AM
Joined Aug 2014
38" span Spitfire - Balsa or Ply
I am planning on building a fuel powered Spitfire with a wingspan of 38". The plan that I have identifies the material to use is balsa. Looking at the size of this model my thoughts are that it might be better to use ply. I have built many rubber band powered balsa models and this will be my first rc build. Should I stick to the balsa or use ply? I would welcome your thoughts, many thanks in advance.
SeanPerry is offline Find More Posts by SeanPerry
Old Aug 30, 2014, 09:33 AM
The Junk Man
Jacksonville, Florida
Joined Jul 2006
Sean, may I respectfully advise you to start with a much less complex model for your first RC attempt? Let alone easier to fly?
"Scale Models" and "First Time RC'ers" do not mix well.
As to the balsa vs. ply question, a model as small as a 38" Spitfire will need to be as light as you can get it to fly well... fuel or electric. If the plans call for balsa, use balsa.
Tom
T_om is offline Find More Posts by T_om
Old Aug 30, 2014, 12:39 PM
Joined Aug 2014
Tom
Tom
Many thanks for your reply. I welcome your advice and have thought a lot about this. My previous post was maybe a little misleading. I have a Hobbyzone Supercub which I am using to learn to fly. I understand that you need to learn to crawl, before you walk and indeed run! I intend to do this. I also have another project which I found on the internet. A fully flying model made from insulating board. This guy posted a video showing how to build and also showed it flying. I intend to follow his guidance also. The Supercub is ok but for me its the build. At present I am building a Keil Kraft Radian .049 control line stunt model. just need to source a Wen Mac. The Spitfire is a long term project. I fully intend to be a competent flyer first before flying any complex build. I will also joint my local RC club.
To that end, thanks for the advice and I reckon I will use balsa for the Spitfire Many thanks.
Old Aug 30, 2014, 01:15 PM
Staffs, UK
Joined Nov 2003
A wingspan of 38" counts as small for an IC powered model and it will definitely want to be balsa. What engine are you planning on using ?
BTW I'd use a diesel on the KK Radian. Wen Macs were never very reliable, even when not antiques. The Radian is a pretty little stunter, but not the easiest thing to fly if memory serves .
Steve
slipstick is offline Find More Posts by slipstick
Old Aug 30, 2014, 01:47 PM
Joined Aug 2014
Steve,
Thanks for that. Not sure what engine I'm going to use. Still researching that. I want to get ready for the build so I'm checking over what I need to know and understand for that.
Thanks for the advice on the Radian. I was looking at a couple of Wen Macs on ebay. After reading your comment I might rethink that. Any advice on types/makes of diesels that would do?
Many thanks for your time.
Sean
Old Aug 30, 2014, 02:16 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I found just a single post on the KK Radian --
Replikit Keil Kraft Radian.
There is a control line forum here --
http://www.rcgroups.com/control-line-63/
eflightray is offline Find More Posts by eflightray
Question 2 ply balsa vs 1/8" lite ply EscapeFlyer Classic Pattern Flying 9 Dec 19, 2013 05:32 PM
Sold Ryan STA Balsa/ply ARF 44" span The Don Aircraft - Electric - Airplanes (FS/W) 3 Nov 16, 2013 11:29 PM
Discussion hunting for a big, beautiful balsa/ply ARF- P40, Spitfire, or P51 RCAddict16 Electric Warbirds 8 Jul 15, 2012 11:18 PM
Balsa / Ply - from LHS or Specialists in Aus? ravencsr Scale Kit/Scratch Built 4 Jun 17, 2005 01:39 AM
Sheeting: Balsa or Glass or Ply or Obechi? green66 Thermal 9 Nov 03, 2002 11:28 AM
