Old Dec 18, 2014, 11:24 AM
Canada, BC, Victoria
Joined Jul 2014
Originally Posted by Ran D. St. Clair View Post
Yes, there is. Go to the OpenAero-VTOL thread in this forum, and at the bottom of the first post you will find the User Manual as well as a spreadsheet that defines the menu structure. Both contain every detail of the XC-142 programming.
I do not recommend that people treat it as a simple recipe. Your aircraft will almost certainly be different in some important way.You need to understand what the parameters mean so you can develop your own set of similar parameters that work for you. The user manual will shortly contain a recommended process for doing that.
http://www.rcgroups.com/forums/showthread.php?t=1972686
Thank you very much, I admit, i'm just a bit lazy, I fly quads and airplanes and look for instant satisfaction but this project is well documented and worth the time, excellent job.
David Volker is offline Find More Posts by David Volker
Build Log Xc-142 malakiblunt VTOLs 76 May 11, 2014 03:52 PM
Discussion XC-142 VTOL Test Aircraft rimshotcopter VTOLs 17 Dec 25, 2013 11:46 PM
Build Log XC-142 VTOL Transport malakiblunt RC Airliners (Commercial, Cargo, Troop Carrier) 63 Jun 05, 2013 04:52 AM
Discussion Xc-142 malakiblunt VTOLs 22 Sep 28, 2010 04:39 AM
Discussion Vtol Xc-142 CESARNOGUEIRA VTOLs 0 Oct 01, 2009 10:25 PM
