Old Oct 16, 2013, 06:53 PM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
New Product
Skywing's Flying-anywhere-size (32-in) Planes
Hi guys,
Skywing is making a series of 32-in 8mm EPP profilers. Their AUWs are about 200 grams (7 ounces). You can fly them indoor or outdoor. Bring some charged packs with you, and you can have a couple of flights during a lunch break.
Currently, there are 3 models available: Edge-540T, Slick, Yak-55, each with 2 color schemes. They come with quality hardware and genuine CF rods and strips.
(Update 1: find build instructions in post #18 http://www.rcgroups.com/forums/showp...4&postcount=18)
(Update 2: PDF English manual added.)
Cheers,
feda
feda is offline Find More Posts by feda
Old Oct 17, 2013, 12:53 PM
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I think I like the Slick the best but I'd like to try them all. :-)
KE Spin is offline Find More Posts by KE Spin
Old Oct 17, 2013, 03:56 PM
Addicted to 3DHS and EF
3Daddict's Avatar
ohio
Joined Oct 2010
looks cool. Could be a replacement for my beat up 3dhs 34'' EPP edge. What will the cost be in the USA?
3Daddict is offline Find More Posts by 3Daddict
Old Oct 17, 2013, 09:53 PM
United States, NC, Leland
Joined Apr 2013
what size motor and servos do I need? anything else ill need?
pharmer1 is offline Find More Posts by pharmer1
Old Oct 17, 2013, 10:00 PM
frankisawombat's Avatar
United States, TN, Mt Juliet
Joined Sep 2013
Look slick.
frankisawombat is offline Find More Posts by frankisawombat
Old Oct 17, 2013, 10:02 PM
I Love 30mm
FlyinAg's Avatar
United States, TX, Wichita Falls
Joined Nov 2001
Very nice! Whats the best place to buy their products?
FlyinAg is offline Find More Posts by FlyinAg
Old Oct 18, 2013, 05:02 AM
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
www.bestvaluerc.com
OMW!!!!!!! I'm getting a red slick!!!! that thing is crazy hot.
now I reckon that weill give the crack pitts a run if not even be better!!!
I saw them on the site now and then came looking for the thread!!
Perfect new toy for Dec fun on the beach.Might even get 2 and add LED's on one of them
any vids yet?
Motor size? 2218?
chop stiX is offline Find More Posts by chop stiX
Old Oct 18, 2013, 08:25 AM
amitghodke's Avatar
Singapore, Singapore
Joined May 2013
hi feda,
What is the recommended power setup ? couldn't find details on motor/ESC .
thanks
amit
amitghodke is offline Find More Posts by amitghodke
Old Oct 18, 2013, 08:39 AM
Taiwan
Joined Oct 2013
Originally Posted by chop stiX View Post
any vids yet?
Motor size? 2218?
FYI
Skywing 32 inch Yak 55 EPP (3 min 40 sec)
not me, of course.
http://www.rcsunnysky.com/kygood/en/...more.asp?id=22
eloog is offline Find More Posts by eloog
Old Oct 18, 2013, 09:44 AM
chop stiX's Avatar
Joined May 2011
I think this little motor will be sweet with 8x4 on a Plush 10A and xgd-9 Servo's
http://www.hobbyking.com/hobbyking/s...00kv_21g_.html
I'd like a nice 5g digital but at $12 a pop I'm kinda put off,want to try keep it relatively cheap,as shipping adds another $22 on the airframe.Those xgd-9's are $4 and I don't think 12g will make it fly bad at all
Well I'm gonna g with that setup on 460maH 2s nanotech
What you all think?
Old Oct 18, 2013, 11:28 AM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Hi guys,
I plan to make the planes available on usa.wattaplane.com. The price should be under $40.
The motor should be a 2204 or 2205. KV should be around 1800. With a 8043 prop and a 2-cell pack, the system should be able to deliver about 400 grams of thrust. The peak current should be just under 10A. So a 10A speed control should be good for the plane.
If the plane is anything like my Piaget (a profiler made of thinner EPP sheets), it should be very durable. So I wonder if using metal gear servos is a good idea. In this way, you will save the trouble of swapping out stripped servos and really have an "indestructible" plane. For good control authority, I am thinking of using 5-gram servos at minimum for the tail and a 10-gram servo for the aileron.
Cheers,
feda
Old Oct 18, 2013, 11:49 AM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
What you all think?
Hi chop stiX,
The motor looks perfect to me except the way it's going to be mounted with 3 screws. Do you have an easy solution?
Regards,
feda
Old Oct 18, 2013, 12:04 PM
3Daddict's Avatar
ohio
Joined Oct 2010
I have found the best servos for this size fomy to be two HS-45 servos for the tail and one HS-65HB for the ailerons.
Old Oct 18, 2013, 01:29 PM
Kansas City, MO
Joined Jan 2000
Ordered the SLick!
Jerry Brown is offline Find More Posts by Jerry Brown
Old Oct 20, 2013, 03:23 AM
chop stiX's Avatar
Joined May 2011
Originally Posted by feda View Post
Hi chop stiX,
Regards,
feda
Hi Max.
What you think og using the xgd-9 servo's?
I will make a plan with the motor mount and cut a 3mm ply that's round which I'll epoxy to the front.
Will see what I'm going to do
New Product Skywing's 48-in Full-fuse EPP MXS with painted color schemes (new!) feda 3D Foamies 589 Nov 12, 2014 05:46 PM
New Product It's a 55-in Skywing YAK-54! feda 3D Foamies 276 Sep 28, 2014 07:07 PM
Off Site Dubro 1 inch tail wheel for .60 sized planes/ 3/32" axle hole aluminum wheel MiG-3 Reno Rocket Aircraft - General - Miscellaneous (FS/W) 1 May 07, 2013 02:11 AM
Sold APC Prop Lot, Electric Props all sizes 32 in all Ifly101 Non R/C Items (FS/W) 1 Jan 27, 2013 03:28 PM
