Old Nov 23, 2014, 07:54 PM
AMA#1032179
Somethin' Extra's Avatar
United States, MN, Fairmont
Joined May 2013
Originally Posted by SteveT. View Post
Put a socket just slightly larger than the blind nut over the blind nut, put a washer slightly larger than the socket over a bolt/screw that will thread into the blind nut, thread the bolt/screw through the socket and crank it down until it pulls the blind nut out....
SteveT.
or i could dremel out the makeshift wooden plat that the blind nuts attached to....but why?
wow that page went fast
Somethin' Extra is offline Find More Posts by Somethin' Extra
Latest blog entry: plasti-dip plasti-damage!
Old Nov 23, 2014, 07:58 PM
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
post some more pics. I am still trying to figure out exactly what you did.
EDIT: oh, did you put the blind nut facing into the wing, as oppose to inside the wing pointing to the fuse?
If so, why can't you just gently pry it out of there?
arnav is offline Find More Posts by arnav
Old Nov 23, 2014, 08:24 PM
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
http://en.wikipedia.org/wiki/Dynamic_soaring
And an explanation from some RCers...
And if you have real flight, you can load up one of the slope soaring sailplanes with a bunch of weight (Shuriken), and then go to the "DS Ridgeline" field, in the "Sierra Nevada" section and kick the speed of the wind up and try it yourself....It is quite fun!!
SteveT.
OK, I get it now. Pretty cool. Thanks for the links!
AeroKen is offline Find More Posts by AeroKen
Old Nov 23, 2014, 09:39 PM
AMA#1032179
Joined May 2013
musta been all those fake links http://www.rcgroups.com/forums/showt...4#post30021869
Old Nov 24, 2014, 02:45 PM
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
Originally Posted by Somethin' Extra View Post
There are a few options here.
1) drill through the bad one and drill it out enough to glue a new one in from the backside.
2) Run a srew thru the existing nut and add a second to the backside with vaseline on the threads and some epoxy on the face and snug it up to the backside of the existing and wait for it to dry. Don't snug it too tight or you'll cause a bind between the 2 sets of threads.
Liberty10 is offline Find More Posts by Liberty10
Old Nov 24, 2014, 08:10 PM
220lb of Canned Heat, baby
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Sold
quadracer is offline Find More Posts by quadracer
Old Today, 01:00 AM
Goes to eleven!
JK13's Avatar
Bellingham WA
Joined Mar 2009
So while repaiiring a wing I accidenly put the anchor in bacwards.....(back part pointint towards fuse...) is it ok or am I going to rip a wing off?
Heat it with a soldering iron till the glue melts and pull it out with a bolt threaded in?
Joe
JK13 is offline Find More Posts by JK13
Old Today, 02:15 AM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
That should work....just don't grab the bolt with your fingers....
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Today, 02:48 AM
Addicted to 3D Flying
RaptorPilot07's Avatar
United States, HI, Maui County
Joined Mar 2013
Rob Holland's flying is amazing...
Rob Holland, "What I See", Rhode Island 2014 (11 min 59 sec)
RaptorPilot07 is online now Find More Posts by RaptorPilot07
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 17, 2011 12:12 AM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 03:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 08:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 11:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 04:19 AM
