Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
You don't have to go through quite as much trouble as this video poster did, as there are a few ways to do this, but here's the basic idea. At 3min in the vid he actually gets to what you need: http://www.youtube.com/watch?feature...v=V0NIepknfnE#! P.S. - My Mcpx smoked a servo the day I brought my Nano home, as I flew it while the Nano charged. Like a kid jealous of it's new sibling.... |
Get it from Sweetwater. They're super-cool & great to deal with: http://www.sweetwater.com/store/detail/FaderLubeS/ You just spray it into the output arm slot of the servo & cycle it a number of times. A second application may be required if there is a lot of oxidization and/or debris in the wiper area. That's all there is to it. Do not apply any oil or other lube to the servo. Also - remember that this won't cure a servo that is truly failing mechanically, but it usually gets rid of the jitters & centering issues that often happen as the servos age, and it prolongs the life of the resistive strip. Joel |
I just ordered some. I'll clean tonight with Q-Tip and use spray when it comes. |
When you're in a hover, the helicopter leans to the right a little bit, so when you turn to the right, it's now leaned forward, and you have to remove that and put the right lean back with cyclic input. That is how the real one flies - if the simulator isn't doing that, then a setting is wrong or it's just a bad model. |
United States, CA
Joined Jan 2012
| Thread Tools | |
| Cool Walkera MiNi CP - Smallest 100 sized 3D helicopter | zadaw | Micro Helis | 5183 | May 24, 2013 04:47 PM |
| Discussion is there anything better than mcpx v2 at same or smaller size? | Legendary_Agent | 3D Electric Heli Flying | 33 | Feb 24, 2012 08:46 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
