Old Jul 17, 2014, 01:54 PM
Joined Jun 2009
Looking for a folding spinner. HK. pusher. 12x6 4mm shaft
I'm about to make a HK order. Looking for a folding spinner and prop. 12x6 4mm shaft that can be mounted on the back of my wing. Non of them specify if you can run the props backward. Any help would be nice. Thank you
jt41time is offline Find More Posts by jt41time
Old Jul 17, 2014, 02:41 PM
fnffishcore's Avatar
United States, MD, Cambridge
Joined Jan 2011
If it's any help, I purchased a couple of these 6x4 props to use on my Flinch wing a couple months ago. If the ones you're looking at are of the same style then I can confirm you can use these on flying wings. You'll just have to reverse the blades so that the lettering faces forward, same as any prop.
A word of caution though...
On both of the ones I purchased, the hole in the nuts that screw down and tighten the yoke are way off-centered, so when the prop spun I got a horrible vibration. They appear to be a common size though (M8 with 1.25 pitch) so I was able to replace them with much better quality nuts from the local hardware store.
fnffishcore is offline Find More Posts by fnffishcore
Found 11x6 folding prop and a 50mm spinner for a 4mm motor shaft radhav Aircraft - Sailplanes (FS/W) 1 Jun 10, 2014 10:55 AM
Wanted 4mm BB Spinner collets for 5mm yoke folding prop flashted Aircraft - Sailplanes (FS/W) 4 Mar 22, 2014 01:33 AM
Wanted 50 - 52 MM Folding spinner 4mm motor shaft Gerardjg Aircraft - Sailplanes (FS/W) 2 Jan 18, 2010 03:48 PM
Wanted 30mm folding prop spinner for 4mm shaft ShaverR6 Aircraft - Electric - Power Systems (FS/W) 5 Apr 10, 2008 03:17 PM
FS: RFM Carbon 32mm spinner for folding props (4mm shaft) kyril Aircraft - Electric - Airplanes (FS/W) 1 Jun 08, 2004 09:57 AM
