Old Jul 21, 2015, 04:07 PM
orvie6 is offline
Find More Posts by orvie6
orvie6's Avatar
United States, OH, Toronto
Joined Oct 2009
Help!
Dr. Mad Thrust Afterburner ring troubleshooting
I have installed one of these units in my latest jet and it was working fine up until now! I have it set up on a seperate mix with throttle and set the offset so it only gets brighter the second half of the throttle setting.
Problem is... Now, after it goes from the 'off' blue, through the brigher blue and should go to orange....it goes to GREEN...then after more throttle is added..the green goes out and NO LIGHTS at all!!! I have adjusted the end points in the mix but so far nothing helps.. The settings are the same as when I had it working before.... I had to change the ESC and since the change...no afterburner!! I calibrated the ESC with the transmitter as usuall.
Anyone have any idea what is wrong?
Wayne
orvie6 is offline Find More Posts by orvie6
Help! Dr. Mad Thrust 40mm 8 Blade EDF Electroplated Version 7000kv/3S jetjocky Micro EDF Jets and Power Systems 3 Jun 29, 2015 11:53 AM
Sold Dr. Mad Thrust 90mm 12 Blade Alloy EDF 1400kv - 3600w (8s) ** Reduced ** Roly72 Aircraft - Electric - Jets (FS/W) 1 May 12, 2015 12:57 PM
Sold NIB Dr. Mad Thrust Alloy 90mm EDF Unit 1000kv-4200w 8S To 10S 11.5lbs Thrust Free Shi chebert Aircraft - Electric - Jets (FS/W) 0 May 06, 2015 09:00 PM
Sold dr mad thrust 90mm power set up maccdaddy Aircraft - Electric - Power Systems (FS/W) 0 May 02, 2015 04:16 PM
Discussion Dr. Mad Thrust 90mm Afterburner Ring Eddie P Foamy EDFs 4 Mar 31, 2014 08:27 AM
