Old Jul 29, 2014, 08:17 PM
flying ninja!
ican3d's Avatar
Joined Jun 2011
Dram, Is that a long zip tie strip around the windshield?
ican3d is offline Find More Posts by ican3d
Old Jul 30, 2014, 02:31 AM
United Kingdom, Scotland, Argyll and Bute
Joined Oct 2012
Hi Ican, Yes it is a zip tie glued on to prop the screen up . I had to make a new screen from a drinks bottle but it needed that extra support.
The poor old girl's almost beyond repair now , I'm looking for the best price replacement at the moment.
Miss my Drifter
drambuidhe is online now Find More Posts by drambuidhe
Old Aug 11, 2014, 01:21 AM
FruityFlight's Avatar
Joined Aug 2014
Hello all. I've been following this thread for a while and finally made an account on here. Also jumped the gun and ordered the Drifter. Just wondering, how balanced is the stock prop? I'm worried about straining the stock motor as I'm planning to run it on the 3s battery that came with the RTF Bixler 2.
Thanks!
FruityFlight is offline Find More Posts by FruityFlight
Old Aug 11, 2014, 07:32 PM
flying ninja!
ican3d's Avatar
Joined Jun 2011
Thanks!
Welcome FruityFlight,
The stock props works well on stock motor, been flying it till this day without a problem. Its not perfectly balance but a quick dab of thin sticky tape will fix the balance issues per-blade and eliminate video wobble. Best lipo will be 2200mah 3s 25c pack (just dont pull the throttle beyond 85% stick to avoid smokin the motor). Make sure you remove anchor weight metal lugs embedded inside the cockpit front nose cone.
Oh btw immediately ditch the stock ESC. Replace it will reliable 20A ESC.
Old Aug 11, 2014, 09:52 PM
Joined Aug 2014
Thanks for the advise ican3d. I did also order the Hobbyking blue 20A ESC so I hope that's a solid ESC replacement. First I just plan on flying it without any FPV equipment on board. Breaking the plane in first.
For FPV I plan on using the Arkbird OSD with the Boscam 200mw vTx and the circularly polarized antenna. I noticed that you use a separate BEC to power the Arkbird. Is that BEC tapped from the main flight pack or do you recommend a second battery to power the avionics so to speak? I have a castle creation 10A BEC that I plan on using if that's the case. Thanks for all for your help!
Old Aug 12, 2014, 03:22 AM
flying ninja!
ican3d's Avatar
Joined Jun 2011
Yes i use separate BEC (5A/5V) mini size (HK-UBEC Pro) tapped from the main flight pack. I don't recomend second battery because of following issues:
1. Weight
2. "Ground Loop" current.
Just make sure your BEC doesn't emitted high RF emission. I had experience with Turnigy SBEC known to capped half my radio range sensitivity.
Discussion Good on-road/drifter? resonatortune On-road Cars 21 Oct 07, 2012 11:48 PM
Discussion FPV Newbie- Seeking ultralight 1S OSD, voltage only? Pete P FPV Talk 0 Jul 05, 2012 03:28 PM
Discussion More Ultralight FPV, added a tilt servo too... KeithLuneau FPV Talk 11 Jun 30, 2008 04:45 AM
