Old Jul 18, 2016, 02:28 AM
Yukinarija is offline
Find More Posts by Yukinarija
Yukinarija's Avatar
Joined Jan 2015
Help!
Naza V2 + FrSky D8R-XP failsafe conflict?
Hey there,
Well I am finally flying! Very happy about that. I had some issues with my failsafes though. There are two scenarios:
1) I panic and I want the Naza RTH mode to kick in.
2) Signal loss and I want the Naza RTH mode to kick in or if that's not available for it to land while reducing power. I am using a Naza V2 FC and an D8R-XP Receiver.
As I can see from The D8R-XP manual, I can set the failsafe to Option 1 (user predetermined settings). http://www.hobbyking.com/hobbyking/s...0X12918X30.pdf
From page 16 of the Naza manual I can see there's quite a variety of things I should be paying attention to - http://download.dji-innovations.com/...t_Guide_en.pdf. It seems to be quite intelligent on its own. Though - if it crashes while returning, does it kill the engines?
The D8R-XP also has this Option 2? (Option-2. How to set failsafe for no pulses on lost signal Just press briefly the F/S button on the receiver while the transmitter is off and you are done. ). As I understand this will give Naza the idea that signal is lost and it will act on its own? Sort of like failsafe?
What is the best setup I could do? I am confused by the terminology here and there and I just want to make sure that I have it properly set. From my own understanding if the Naza is flying and I cram it into failsafe it should RTH? So it makes most sense to save that mix into the D8R-XP as the failsafe default (Option 1) and I am done?
TYVM.
Yukinarija is offline Find More Posts by Yukinarija
Sold Frsky DJT JR module w/ Frsky D8R-XP weldmonkey Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2016 02:06 PM
Sold Alien x500 v2 NAZA Lite, DJI E300, FrSky D8R-II plus Naptown Aircraft - Electric - Multirotor (FS/W) 0 Nov 18, 2015 04:15 PM
Discussion FRSKY D8R-XP PPM/Naza blueprint Multirotor Talk 0 Mar 07, 2014 04:55 PM
Discussion Naza Lite + Frsky D8R-Xp Help. No Tx response in assistant. Home_Nucleonics Multirotor Electronics 1 Feb 09, 2014 11:55 AM
