Old May 09, 2016, 03:31 PM
slyme is online now
Find More Posts by slyme
Simon
slyme's Avatar
United Kingdom, Gosport
Joined Apr 2016
Question
NX3 EVO - Installation question.
Hi,
I have posted this question in another thread but the thread seems to have spluttered into lifelessness. I hope it's okay to post it again here as a new thread.
I have just purchased one of these NX3 EVO units. It was a bit of an impulse buy, I suspect it may be a cheaper solution than the units I have been looking at (E-Flite and Hobbyzone SAFE rx's) or it might not be what I want at all! I'll see ...
I'm a bit baffled in respect of the wiring route ...
Out:
Aileron R - I'll plug my aileron in here, I have one central servo for the ailerons
Aileron - nothing here
Elevator - elevator here
Rudder - rudder here
So far, so good ...
In:
Emerg - I'm guessing aux1 from the rx and assign to the trainer switch on the tx to get a 'panic button'?
Aileron R - aileron here
Elevator - yep, this one's simple, elevator goes here.
Multi - I don't really understand this one but I have figured out that if I use the 'multi cable' supplied and plug the red one into my rx rudder output then I have rudder control
Have I got this lot correct? It seems correct but I'm not trusting to my judgement here.
Where/what do I plug in to get a switch in order to change flight mode in flight?
Any help will be greatly appreciated, thanks,
Simon.
slyme is online now Find More Posts by slyme
Old May 09, 2016, 05:13 PM
GottaZoom is online now
Find More Posts by GottaZoom
Up! Up! And Away!
GottaZoom's Avatar
Joined Feb 2014
Here's a thread where some people who've used that gyro may be subscribed, even if the thread is not active.
http://www.rcgroups.com/forums/showthread.php?t=2497975
My guess would be that Aileron R is for the right aileron if using 2 servos, might want to use the other port.
Didn't see TX mentioned, and how to link switch to channels varies by TX - might try a TX thread for that. Examples: My DX6i is channel 5 is Gear switch and 6 is flaps switch. My T6 will vary switch for some functions/channels by menu selection.
GottaZoom is online now Find More Posts by GottaZoom
Old May 10, 2016, 10:46 AM
slyme is online now
Simon
slyme's Avatar
Joined Apr 2016
Thanks GottaZoom - I have posted into that thread.
Discussion MAT NX3 EVO aircraft GYRO KenCz Flight Accessories 20 Jul 07, 2016 12:42 PM
New Product HC-MAT NX3 EVO 3-Axis Flight Stabilization System & Door Sequencer Controller hobbyclub 3D Flying 20 Jun 08, 2016 12:12 PM
Discussion NX3 Evo $30 alternative AS3X SAFE™, “panic” feature diydrone Electric Plane Talk 75 May 31, 2016 04:30 PM
New Product HC-MAT NX3 EVO 3-Axis Flight Stabilization System & Door Sequencer Controller hobbyclub Flight Accessories 0 Nov 02, 2014 11:39 AM
