Old Sep 25, 2015, 07:29 PM
rotarypower101 is offline
Find More Posts by rotarypower101
rotarypower101's Avatar
Joined Jan 2012
Proper Solder and Flux for Aluminum Lipo tabs?
Which solder and flux should I purchase to solder aluminum lipo tabs with a temperature adjustable Weller soldering iron capable of 850*F?
What alloy is the proper solder to use for adhering to aluminum?
Are there any solder alloys to avoid soldering aluminum?
Is the Aluminum Flux the most important part of the equation?
I would like to know from first hand experience which products to buy, and from where to get a quality bond please.
Any tips to make the soldering process better would be helpful if you have done this before.
Thanks!
I have searched, Need specific products that are known to work properly from first hand experience for this application.
rotarypower101 is offline Find More Posts by rotarypower101
Old Sep 25, 2015, 10:18 PM
kamcoman is offline
Find More Posts by kamcoman
Douglasville, GA
Joined Sep 2004
Took almost 5 seconds to find this on the Internet. en.wikipedia.org/wiki/Soldering www.wikihow.com/Solder-Aluminum Don't know how accurate it is but EAA homebuilt airplane builders have been soldering/brazing/welding aluminum for years. Keith
kamcoman is offline Find More Posts by kamcoman
Old Sep 25, 2015, 10:32 PM
kamcoman is offline
Douglasville, GA
Joined Sep 2004
Here is a link to aluminum solder and within the link there is a flux available from the same supplier. http://www.harrisproductsgroup.com/e...older-500.aspx
Old Sep 25, 2015, 11:58 PM
eKretz is offline
Find More Posts by eKretz
Joined Jun 2015
You actually don't need anything special at all to do it. I've done it for years with the exact same equipment that I use for electronics work. You do need a little help with technique though. Here's what you need to do:
Get the stuff you want to solder cleaned with a bit of sandpaper or whatever in the spot you need to solder it. This will knock down the oxide layer so it's very thin (aluminum oxidizes on exposure to air nearly instantly, so the best you can do is make the layer as thin as possible). Some guys like to use liquid flux or some light oil while they abrade to keep the oxide layer from coming back, but this isn't necessary. After you have everything cleaned and positioned, fire up the soldering iron and get a good sized blob of solder melted on the tip. I suggest a large tip for thick aluminum work, as it wicks heat away fast. If it's only an aluminum tab a regular tip will be fine.
Apply the tip and blob to the work where you want to solder, and use a scraping motion along with a little pressure (usually about the same pressure as one might use when using a pencil eraser will do it) to scrape the oxide layer away while the surface is covered with the solder blob. The layer will be scraped away and the solder will tin the surface. If you are joining two aluminum parts together, you should individually tin both parts, then afterward join them together. If attaching copper to aluminum, tin the aluminum using this method, then solder the copper to the aluminum just like you would normally for a copper/copper joint.
Have fun, and report back on how it goes.
eKretz is offline Find More Posts by eKretz
Old Sep 26, 2015, 08:08 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
https://www.google.com/search?q=sold...utf-8&oe=utf-8
Practice on tabs from an Al soda can.
hoppy is offline Find More Posts by hoppy
Old Sep 26, 2015, 02:08 PM
Joined Jan 2012
Has anyone here actually done this?
I can solder with the best of them, thats not the issue.
I require the proper products to make a easy quality job of it, and to reduce the amount of heat soak needed to tin the surface of the tab.
I believe there is a specific alloy, tin/zinc that works better for this, I think there may be an issue using a Pb based 60/40 and I believe there is a specific aluminum flux that helps get the bonding to activate quickly.
I would like some good ideas about how to limit heat traveling from the tab to the PVC lipo casing. Thinking maybe clamping to the tab to prevent heat transfer?
And just to be clear, we are NOT brazing or using a torch of any kind...
This needs to be done at low temperatures ~500*F
Old Sep 26, 2015, 02:38 PM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
http://www.messerwelding.com/Product...t/MG%20460.pdf
This is the stuff I use and seems to work very well.
Comes with the solder and a small bottle of flux.
Bought it at a local welding supply shop.
Also know that some cells come with one side of the tab plated with nickel, so ordinary solder works on these. To look at it, you couldn't tell it was plated. the only way to tell is, try tinning both sides with lead/flux filled solder. If it tins, your lucky.
Gord
flypaper 2 is online now Find More Posts by flypaper 2
Old Sep 26, 2015, 02:59 PM
Joined Jan 2012
Gord
I have, and I am not lucky unfortunatly...
Any idea how liberal we can be with the plastic containers to avoid issues with delimitation from the tabs due to heat damage?
I would much rather ask and learn from those that have struggled through to understand, than ruin items if a little patience and understanding can get me there successfully .
Question soldering LiPo's - aluminum tabs???! CactusJackSlade Batteries and Chargers 35 Mar 29, 2016 02:20 PM
Discussion Al compatible solder and flux for soldering Aluminum Lipo tabs? rotarypower101 Multirotor Power Systems 10 Sep 29, 2015 11:47 AM
Discussion Where to buy Solder-It or Zinc flux and solder for lipo tabs in Aus?? Ampdraw Australia 3 Aug 16, 2010 04:31 AM
Question How do you properly solder lipo tabs? ray foley Batteries and Chargers 19 May 31, 2006 04:17 PM
Help! Soldering aluminum tabs on Lipos!!!!!!! rick121x Batteries and Chargers 19 Dec 19, 2004 07:04 PM
