Old Mar 10, 2010, 11:14 PM
verticalflight is offline
Find More Posts by verticalflight
Boom goes the dynamite!
verticalflight's Avatar
Palo Alto, CA
Joined Dec 2003
F5Bbox for verbal climb counting and set times
So this is what happens when you have too much time on your hands... I had a custom F5B talking timer built to help with my F5B practice and competition. It's a verbal climb counting and leg set timing tool for use during an F5B flight, and then stores this data for immediate review after a flight.
For me, it solves 3 problems:
- Your helper forgets what climb count you are on
- Your helper doesn't exactly know when you should fly your 6 leg sets
- Its too difficult to use the Unilog to know during and right after a flight which sets were the best/worst, how fast the 4 or 6 leg set was exactly, and what the motor on time was (immediate feedback during practice)
How it works:
- F5Bbox connects to a spare receiver on the ground
- The connection is made via a switch that is plugged into the throttle signal
- Throttle signal is used to determine when and for how long the motor is on
Verbal climb counting:
- After each climb, the F5Bbox says the climb count verbally
- After 10 climbs it says Distance over
- A motor cut will not increment the climb count, but it does increment motor on time
Set timing: (optional on or off)
- After stating the climb count, it tells you the number of seconds ahead/behind you are against the cumulative standard 20 second set time.
- Being ahead of the cumulative 20 second set time means you can attempt a 6 leg set in the following climb.
- Sets are defined as the entire time for one “motor on” plus the time between the end of a “motor on” and the beginning of the next “motor on”.
- So it actually says "2 climb, 4 ahead".
Data recorded for every climb:
- Set time and motor on time
- Total remaining time and total motor time
- You can view up to 20 flights of data in the memory
- You can export via serial cable to the computer
I'll post a video in a few days...
verticalflight is offline Find More Posts by verticalflight
Old Mar 11, 2010, 12:33 AM
jfseaman is offline
Find More Posts by jfseaman
It's alive, alive!
jfseaman's Avatar
Cambria, Ca
Joined Apr 2004
How can I get one?
jfseaman is offline Find More Posts by jfseaman
Old Mar 11, 2010, 08:28 AM
ChickenStick is offline
Find More Posts by ChickenStick
The sky is falling!
ChickenStick's Avatar
Cleveland, Ohio
Joined Nov 2005
Nice...
But if your are going to start production...
1) Serial port will need to be replaced by a USB (but I do like old school)
2) China will need a set of schematics so they can started on a smaller/cheaper model
- Cliff
ChickenStick is offline Find More Posts by ChickenStick
Old Mar 11, 2010, 09:07 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Neat! Count me in for a smaller version with more bling bling I can hang around my neck...
WimH is offline Find More Posts by WimH
Old Mar 11, 2010, 11:00 AM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Kris,
To finish off our e-mail communication as the project went on...... great work!!!
Indeed, i think perhaps a little youtube video would be very effective in showing what it would be like to have the box. Either a dry run in the living room or a real flight with the audio in the background.
Joe
jjmouris is offline Find More Posts by jjmouris
Old Mar 11, 2010, 11:28 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
Aiiie, Joe helped in the development, sure it won't blow up when flying too much legs?
On a more serious note, I've been dreaming about something like that , but integrated in my TX. This is actually a better idea. Would it be difficult to make it start my talking timer automatically after 200 seconds as well? I'd certainly want one then....
Old Mar 11, 2010, 01:06 PM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
Looks like a great idea Kris!
I'm interested.
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Mar 11, 2010, 01:25 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Wim, i would not say i helped. We just talked about what we would want to have. For instance i thought it would be distracting to have the unit say something during the climb so we put a delay in and also a switch to make it talk less. It is a bit big, i did ask for something that would fit in my pocket but i guess you can't have it all.
Kris did it all him self and then got someone to build the units for him.
Old Mar 11, 2010, 09:48 PM
Palo Alto, CA
Joined Dec 2003
Thanks guys. I am not planning to make a production run of these. But I do have a few extras that I had built with my prototype.
Here is an sample data set off the F5Bbox:
Flight#5
#1 SET:17.2 MOTOR:3.2
#2 SET:17.1 MOTOR:2.2
#3 SET:27.4 MOTOR:3.1
#4 SET:16.9 MOTOR:2.5
#5 SET:17.1 MOTOR:2.4
#6 SET:28.7 MOTOR:3.2
#7 SET:17.5 MOTOR:2.4
#8 SET:18.5 MOTOR:2.5
#9 SET:19.1 MOTOR:2.2
#10 SET:19.2 MOTOR:2.5
Total Time: 0:02 Distance Motor: 26.2
Old Mar 11, 2010, 09:53 PM
epwierman is offline
Find More Posts by epwierman
epwierman's Avatar
Joined Aug 2004
Nice work dude, good to see the actual resultant hardware. I like the display and verbal cues you decided on. Very well done!! -Eric
epwierman is offline Find More Posts by epwierman
Old Mar 11, 2010, 10:07 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
I'd like to see a demonstration in the living room... with motor running. Very cool work!
Troy is offline Find More Posts by Troy
Old Mar 12, 2010, 06:38 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
Flight#5
The "set" time does not include the motor time?
Old Mar 12, 2010, 09:33 AM
Palo Alto, CA
Joined Dec 2003
Wim yes it is does, that is just some sample data. I will make a vid hopefully this weekend.
Old Mar 12, 2010, 09:56 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
ah, ok, it's just because I've never timed a "6" set under 30s yet...(never timed Joe either...)
Old Mar 12, 2010, 05:19 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Wim, i was just about to say..... not everybody needs 25 seconds for 4 legs.
Discussion Run times and charge times for E-Revo Brushless player73 Electric Power Cars 3 Oct 21, 2009 06:18 PM
For Sale Verbal Advantage Success Edition 24 c.d.'s bob_nj Non R/C Items (FS/W) 3 Jan 15, 2009 06:40 AM
Discussion Climb angle for best rate of climb? mnowell129 Modeling Science 113 May 03, 2008 01:29 AM
Discussion set up for longer run times on Swift rmasu Electric Heli Talk 9 Jan 20, 2007 12:27 AM
best trex set up for flight times stevenkelby Mini Helis 18 Dec 31, 2004 04:29 AM
