Old May 13, 2016, 05:00 AM
kestrel0222 is offline
Find More Posts by kestrel0222
AMA Member Since 1973
kestrel0222's Avatar
Michigan
Joined Jul 2007
Question
Radio?
Hi everyone,
It’s been a while since I’ve posted here. I am re-entering the hobby of R/C flying.
I started flying back in 1974 and flew until 1987. My aircraft of choice was what is now called “classic pattern” and scale aircraft. Now that my children have grown and left the nest, I find myself wanting to re-enter this great hobby. However, this time, I will be flying sailplanes.
Obviously, a lot has changed since the late ‘80s, especially with radio technology. As I start to research which radio to purchase, there seems to be a lot more options.
Sorry in advance for the “simplistic” question, but what type of radio should I be looking at? I am looking for a radio system that has at least 4 channels (possibly 6 channels – for future use). Any advice/suggestions would be a great help.
Thank you,
Tom
kestrel0222 is offline Find More Posts by kestrel0222
Old May 13, 2016, 06:31 AM
JeffD is offline
Find More Posts by JeffD
Joined Mar 2000
Any radio you buy today will have way more features than what you're use to. Also, it will be on 2.4GHz rather than the 72MHz you were using in the '80s.
But you need to give a little more info to get a good recommendation. How much do you want to spend and what type of models do you intend on flying in the future? Do you want to have to figure out how to program models from scratch or do you want the radio to be pretty much pre-programmed for a glider?
JeffD is offline Find More Posts by JeffD
Old May 13, 2016, 08:05 AM
glidarflyar is online now
Find More Posts by glidarflyar
glidarflyar's Avatar
Joined Jun 2008
Planning for 6 channels is a good idea for sailplanes. Most flown today have an electric motor in the nose, something not even though of back in the day.
You will also find that not many hobby shops will have glider kits... or can or will even get them for you. And what they can get cost more than a new car cost back when some of us started flying. What is available today are arfs, and very, very few are Gentle Ladies.
I just got a new model Spektrum DX8 Generation 2 transmitter. It was listed at $299 retail. It talks. And has alarms. Or will vibrate/buzz the warnings. And comes with a battery that's about four times the storage we had early on.
It also has special functions specifically for sailplanes, acro, helicopter and multi-rotor. The sailplanes sold are ARFs and often have 3 or more position flaps and a "crow" setting that trims both ailerons up (or down) when the flaps go down (or up). A bunch of the things we did back in the day to gliders to do those things were done with mechanics. Heck, the Oly II spoilers were pulled open by strings. Turns out all that stuff is easily done in the new transmitters by setting some switches. Of course, ailerons now need 2 channels instead of one, and we might have 4 servos in the wings. But the radio and it's special settings are what gets it all to work.
To see what's available take a look at an example. http://www.horizonhobby.com/product/...mode-2-spm8000 Amazing compared to yesteryear....
glidarflyar is online now Find More Posts by glidarflyar
Old May 13, 2016, 08:07 AM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
Look at a Graupner MZ-12. Great 6 channel transmitter and a good value. uses the HOTT system which have telemetry. Not only does the transmitter have the usual programmability but so do all of the receivers and servos. This means that if there is a feature that you can't program within the transmitter you can probably do it in the receiver. About $150.00 with a 6 channel full range receiver.
Mark Miller is offline Find More Posts by Mark Miller
Old May 13, 2016, 08:52 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Spectrum DX6 has alot of features and priced well. there are many options on RX's. clone stuff also on DSM-2/ DMS-X.
You need to read some as many good radios out there. Horizon hobbies has great customer service and support.
Futaba has good sets. Airtronics name is gone but Sanwa is maker of them still around. Hi-Tech makes good radios. You most likely get alot of other input here.
dankar04 is offline Find More Posts by dankar04
Old May 13, 2016, 09:07 AM
Michigan
Joined Jul 2007
Thanks for all your replies!!!! You all have given me much to think about and have given me a direction to go in.
As for "kits".... I plan on purchasing a kit like the SIG "Riser", or :Gentle Lady" as mentioned above to get acclimated again to flying. .
As far as future planes, I am a scratch builder... I have designed and built many model aircraft back in the 80's, this included scale and pattern aircraft. So, going forward, my plan is to build future models from existing plans that are widely available on the "web" today.
I flew a lot of scale models in the past, so I am leaning toward scale sailplanes.
As far as budget is concerned, I'm looking around $300 -$400 range.
Again, thanks for your replies,
Tom
Old May 13, 2016, 10:06 AM
Scot S is offline
Find More Posts by Scot S
United States, MA, Westford
Joined Nov 2005
check out www.scalesoaring.com for some great info on scale aero-towing. Neat stuff.
Scot S is offline Find More Posts by Scot S
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
For scale models you probably want at least 12 channels. The Graupner mz-24 is on sale right now for under $400. Comes with a 6 and 12 channel RX, both with built in telemetry.
Tom
Kiesling is online now Find More Posts by Kiesling
Old May 13, 2016, 10:12 AM
p9o1r1sche is offline
Find More Posts by p9o1r1sche
figgerin' things out
United States, NC, Hendersonville
Joined Apr 2014
I would recommend a 7 ch radio at least. You would be covered for a motorized full house glider. One with mixes available would be good also.
p9o1r1sche is offline Find More Posts by p9o1r1sche
Old May 13, 2016, 10:16 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
The Riser is stronger then G/Lady. G/Lady is a good flyer but so is Riser. Riser is also cheaper. Main diff is wing. Either glider flys well.
Old May 13, 2016, 12:10 PM
Alienmenacet54 is offline
Find More Posts by Alienmenacet54
Alienmenacet54's Avatar
United States, NE, La Vista
Joined Oct 2014
Tom
If you are into scratch building, you might want to check out Outerzone.
http://www.outerzone.co.uk/index.asp if you don't know about it.
I have a very cheap, but a great little radio for my sailplane/glider. It is a FlySky FS-I6, it's a 6 channel. Mine came with a park flyer receiver. But you can get the full range rx also. I have had no trouble with.
But Turnigy has the same radio under their banner too. http://www.hobbyking.com/hobbyking/s...dproduct=74037 for 54.99. And the Turnigy TGY iA6B V2 full range receiver to enable all flight telemetry.
Alienmenacet54 is offline Find More Posts by Alienmenacet54
Old May 13, 2016, 12:44 PM
Sailhigh is offline
Find More Posts by Sailhigh
High Lift Coefficient
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
Tom
Agreed.
Sailhigh is offline Find More Posts by Sailhigh
Old May 13, 2016, 03:03 PM
RV Winkle is offline
Find More Posts by RV Winkle
United States, KY, Bowling Green
Joined Aug 2013
Tom
You may want to ask yourself how comfortable your are with radio programming. We did not do that back in the day. There is a range of TX and programming features. I went with a simple setup 6 channel but 8 seems to be the new 6 and mine is not programmable beyond features for each aircraft. Other systems talk to you and appear to need the occasional software update.
It is just something to think about. I kinda miss metal TX and nicads.
JCW
RV Winkle is offline Find More Posts by RV Winkle
Old May 13, 2016, 04:02 PM
Michigan
Joined Jul 2007
Again, thanks to everyone that replied to my original post!!! Wow, so much great info!
JCW.... I think I will be going with a 6 or 8 channel system as you described above. I think this will be best for me at this time... And yes, I too miss the older systems with nicads and metal transmitters!
My last radio was a Futaba 6 channel that was all metal construction (transmitter). Before that one, I had a Kraft radio (showing my age).
Thanks for all your replies,
Tom
Old May 13, 2016, 04:47 PM
Joined Jun 2008
A builder? cool....
Take a look at the laser kits at http://www.skybench.com/index.html?h....com/home.html
Never had a Kraft but wanted one. Did have a galloping ghost that had an escapement on the other channel. Back then we didn't even dream of what todays TXs can do for $300.
As for how many channels.... My Avia2.5 was programmed into my DX8 to do crow and full wing camber changing and has a V tail. Ailerons took 2 channels. Motor, elevator, rudder and flaps needed 4. Truth is, it's a thrill to see all that working, but the sucker didn't get loaded in the car the last 5 flying sessions. I took a $115 Vista ARF to fly with the budding glider bunch since they think the Avia is cheating. And that (GentleLady clone) Vista broke 1000' again and again. It's just now gotten a Vario installed (since getting the DX8G2), but that's coming out tonight. They think that's cheating too.
Sold Radio Carbon Art DVD'S (Performance Tunning - F3 Build Clinic - Radio Clinic) L. New! luis94 Aircraft - Sailplanes (FS/W) 1 Apr 26, 2016 04:27 PM
Sold 2 Planes and Radio RTF -EPP Slope Wing and Hand Launch Glider Combo RTF w/Radio fuadramsey Aircraft - Sailplanes (FS/W) 1 Feb 24, 2016 11:07 AM
Sold 2 Planes and Radio -Powered Glider AND Slow Flyer Combo RTF w/Radio fuadramsey Aircraft - Electric - Airplanes (FS/W) 3 Feb 24, 2016 11:05 AM
Discussion Car Radio vs Air Radio for Vehicle FPV pc_pilot FPV Talk 27 Jan 16, 2016 02:02 PM
Discussion Wanting more reliable radio module for 9x. Is my radio dead? RcPro97 Radios 2 Jan 05, 2016 02:54 PM
