Old May 27, 2012, 12:22 PM
ehawthor is offline
Find More Posts by ehawthor
Carbon Cub SS
Canada, MB, Selkirk
Joined May 2012
UMX Carbon Cub SS Repairs
Flew my CC for the first time last night and ended up breaking prop shaft and bending and creasing elevator wing. To replace prop I have to open up the plane by cutting tape that holds the two halves of the plane together and tape or glue elevator wing.
Looking for any advice tips or tricks in plane repairs.
ehawthor is offline Find More Posts by ehawthor
Old May 27, 2012, 02:36 PM
makg is offline
Find More Posts by makg
ISP Supervisor
makg's Avatar
United States, AK, Fairbanks
Joined Jan 2006
When I replaced my prop shaft, I didn't even cut it all open. Slice the Carbon Cub decals on the sides of the cowl, then get your finger on the motor so it wont turn when you unscrew the 3 screws or when you install the new adapter.
makg is offline Find More Posts by makg
Old May 27, 2012, 10:18 PM
Joelster is offline
Find More Posts by Joelster
Joined Dec 2011
Where did you get the new shaft from, and what's the part number?
Joelster is offline Find More Posts by Joelster
Old Jun 01, 2012, 06:23 PM
ehawthor is offline
Carbon Cub SS
Canada, MB, Selkirk
Joined May 2012
Picked up prop shaft or prop adapter from LHS part number EFLU4167. Part numbers can be found in the supplied manual. There is also a long prop adapter available part number EFLU1168. Have not had a chance to replace, but will this weekend.
Old Aug 31, 2012, 09:52 PM
ncutler is offline
Find More Posts by ncutler
Joined May 2008
Hate to bring up an older post but my question fits right into it.
I'm onto my third Long Prop Adapter for the SS Cub after twice nosing into the ground broke them. Does anyone know of a solution to this what seems to be a weaker part of the plane? It always seems to shear at the thinnest part of the adpater. Wondering if there are alternatives to the long prop adapter since my last breakage happened only falling 6 feet after I added up instead of down compensation on the elevator/flap mix and it stalled upon takeoff, falling 6 feet into long grass and still it broke.
Any such thing as metal options or changing the configuration to avoid the long prop adapter? Otherwise I guess I'll order a bunch of long prop adapters??
ncutler is offline Find More Posts by ncutler
Old Nov 09, 2012, 04:14 PM
Pgritt is offline
Find More Posts by Pgritt
Joined Nov 2012
Broken prop adapter
My prop adapter broke on my first flight. I noticed it broke at the end of screw that holds the prop. I went to longer screw that will extend into the thicker part of the adapter this should help
Pgritt is offline Find More Posts by Pgritt
Old Nov 09, 2012, 05:33 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Get a prop adapter from ICU on shapeways.
Almost indestructible.
airpower is offline Find More Posts by airpower
Old Nov 10, 2012, 08:57 AM
Pgritt is offline
Joined Nov 2012
Shapeways prop adapter
I have some on order but won't show up until abut Nov 20th
will let you know how they work out
Old Nov 11, 2012, 10:02 AM
Robert Cline is offline
Find More Posts by Robert Cline
Robert Cline's Avatar
McKinney, Texas
Joined Apr 2009
Prop adapter.
My original prop adapter also broke very easily. I replaced mine with the shorter Sbach adapter and have not had any problems. Just use the supplied spacer. Prop now has held fine. Spacing now looks more scale and not hanging out on a limb.
Robert
Robert Cline is offline Find More Posts by Robert Cline
Old Nov 12, 2012, 10:23 AM
makg is offline
ISP Supervisor
makg's Avatar
Joined Jan 2006
I second the ICU prop shafts. I broke several stock CC shafts and haven't broken a ICU prop shaft since I installed it.
Old Dec 05, 2012, 08:46 AM
Pgritt is offline
Joined Nov 2012
I got two adapters from shapeways but they are the short one that won't fit the CC
how did you make yours work??
Old Dec 05, 2012, 03:43 PM
makg is offline
ISP Supervisor
makg's Avatar
Joined Jan 2006
Just use em, they are a little short but will work.
Old Dec 15, 2012, 02:59 PM
Pgritt is offline
Joined Nov 2012
CArbon cub aileron servo replacement
Crashed my CC again (3 for 3) and broke the wing just inboard of the aileron servo so the wires pulled off the servo. Tried to solder them back but must have fried the servo with the heat
Bought a new servo (spectrum SPMSA2030LO 2.3 gram linear long throw offset servo) installed it and tested the controls. the new servo is offset so that you get a small amount of up aileron and a large amount of down. The problem is the other wing seemed to be offset the other way.
In the package with the servo is a short jumper wire with a yellow female connector on one end. I think this is a servo reverser. but when I plugged it in it not only reversed the servo travel direction is appears to have changed the offset programing. I manager by playing around to get the servo on the other wing to have the same offset as the new one. Don't really understand what is happening but since both ailerons now act the same I will try flying this way. Large defection up and small deflection down on both wings.
Anyone know what is really going on here??
Old Dec 15, 2012, 04:38 PM
harrye is offline
Find More Posts by harrye
United States, CA, Pleasanton
Joined Apr 2002
Looks like ICU has two different sizes of prop adapters for sale;
"Small" cm: 1.176 w x 1.176 d x 1.176 h in: 0.5 w x 0.5 d x 0.5 h $3.00
"Large" cm: 2.908 w x 2.512 d x 1.124 h in: 1.1 w x 1 d x 0.4 h $4.50
Which should I get for the Carbon Cub ?
TIA.
:harry
:harry
harrye is offline Find More Posts by harrye
Old Dec 15, 2012, 07:58 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Pgritt, you have it incorrect, the ailerons are suppossed to have more up than down. Reverse the servo that has more down than up.
Discussion UMX Carbon Cub SS Mod Thread MinneFlyer Micro Ready-to-Fly 995 Jul 03, 2016 02:00 PM
New Product UMX Carbon Cub SS masonjee Electric Plane Talk 10 Mar 14, 2014 01:03 PM
Discussion UMX Carbon Cub SS repairs ehawthor Canada 1 Jun 04, 2012 04:11 PM
Sold E-Flite UMX Carbon Cub SS BNF (new in box) PatternFlyer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 12 May 08, 2012 09:15 PM
