A friend had his Flash at the park last weekend and had the LG mod. He used two pieces of plywood, one on top and bottom with some heavy duty CF LG. Put through bolts in and it's VERY sturdy.
Anyone try GensAce lipos? they have a 10% off sale and the 450 25c are about $4.00 and the 1000mah 25c are about $7.20. I ordered seven so I'll see how that goes. Ordered Monday and received them today . Orders over $50.00 ship free .Saw the new Flash on Twisted Hobby's website. Very Nice! Is anybody else selling the RCFactory kits? |
Joined Feb 2008
After a couple flights with the Flash today, I prepared to hand launch again. I should have waited for the wind to calm, but I thought it was not too bad. A gust caused it to veer. I was able to save it from hitting stuff behind the flight line, but crashed out in the field. Knocked the motor off. Hopefully I can get it glued on straight and all will be well again. The CF strips are still intact, but the four foam pieces next to the motor came off. I started flying the Flash this Spring and so far tore off the LG and motor. Not too bad for a 3D plane. Many don't last too many months. The LG repair was a great success and it has been standing up well to landing in the grass. Hopefully the motor will go on as well.
I started glueing the foam pieces back in place. Tomorrow I will probably finish the repair when today's glueing dries. Besides the pieces that were tore off there was a crack along the fuse where the verticle part of the lower fuselage met the horizontal part of the fuselage. |
Joined Feb 2008
I am just going to glue it back like it was. The strength was ok. From altitude with power a dive to the dirt. Something will break. The front came off and a little glue and all will be ok. If The front would have held then the fuselage in the middle would of broke. I had a Insane Foamies Yak and that is what happened to it. Of course I did it like six times in three years to the Yak. Not bad for 3D even on days with 18 MPH gusts. Who wants to wait for those perfect days to fly.
Joined Feb 2008
This weekend I finished the repairs to the Flash that I crashed from altitude nose first. I flew my Eflite Cap while the Flash was down. So today after flying my small Extra Slick I felt the conditions perfect and tested the Flash. Flew 3 flights and it was like before the crash. I was instantly in tune with the Flash after a month down time and it flew as well as before. No difference. It is hard to tell where the break was. After the crash there were a couple little pieces of foam that had tore loose. In the wind one got away. When I repaired the nose of the plane, I took a little piece of scrap EPP and tore it to the right size. I then put Foam-tac on the foam and pressed it in place smoothing it. Can't tell where the piece is. Looks like all the rest.
Belfast / Dublin
Joined May 2004
just tried the 350 mAh nano-techs from Turnigy in the Flash
I went from a 45g Scorpion with 1200 Hyperions to a 30g MicroDan with these little 350 nano-techs (18g weight lost off motor + mount ...and 75g lost off battery) all I can say is WOW ... floats like a feather climbs like a home-sick angel ![]() still have to do the Rx change to the 2g FrSky ... but that's for another day ... the weight loss totally transforms this plane - the down lines and the up lines are now just about same speed ... and everything else in an eerie slo-mo
Belfast / Dublin
Joined May 2004
yeah maybe this is becoming an obsession haha ... the last few grammes will have a tiny effect... but it's not just 4g off the Rx it'll be another 4 or so off cables too ... hehehe
not sure of the exact weight but she's definitely under 400g flying weight i get 4 and a half mins flight time from the 350's so I fly with 4 packs... the plane has really come into its own in this guise ... it has always been a great flyer but it's a whole new level of 'smooth' and consistency ... seeing the upline and down line identical in pace, and the turn at the top graceful and weightless and slow... mesmerising ... normally people see it and think "oh that's nice" ... ...now i get "oohs and aahs" ... quite amusing
Munich (Germany)
Joined Oct 2010
Hi,
I am nearly ready to buy a RCF flash as first light airplane -> I was flying 1.4m balsa plane some years ago. Now I am mainly flying helis and a 60cm quadcopter What would be a good beginner setup for a flash build (circuit, loops, rools) because there is too much motor choices on hobbyking/same for 9g servos . What is the best prop size for a flash? Does a better beginner model exist now? compared to 2009/2010 |
Belfast / Dublin
Joined May 2004
hi milliotseb, this is a really great plane... i've been flying mine for a couple of years and still absolutely love it
originally mine was flying at about 460g... now she's flying at 367g exactly - (soon to be 361g) as a basic set-up i'd recommend decent 9g servos - i've been flying HXT900 which are super cheap and perfectly adequate... the rudder servo needed replaced once but the others have all been perfect I use a very light 15amp Kontronik esc which i happened to have but any 12-15 amp will be fine - turnigy plush is always a good choice and they are affordable motor wise it gets tricky ... my set-up used to be heavy with 1200mAh 3s lipo and a 45g scorpion motor...this set-up works quite well but what i have now is IMHO vastly preferable now I use MicroDan 2505 3D 1200kv motor which draws about 10 amps with a 9x5 HD (GWS) prop you could use an equivalent ICBM (inexpensive chinese brushless motor ) but the MicroDan is in another league IMHO and tips the scales at 30g odd. At $55 its not exactly cheap but you'll be laughing.i wouldn't go any bigger on the prop for reasons of ground clearance... a bigger prop will chew grass and thereby shorten the bearing-life of the motor with the little MicraDan you can run Turnigy nanotech 350mAh 3s lipo for about 4- 4.5 mins flight time as its only drawing said 10amps ... a bigger motor like the scorpion will draw 15 to 17 amps which will require an appropritely sized esc and a battery that can deliver same. as it is, this is an super lighweight set up and it just floats like a feather yet can pull unlimited vertical ...hope this helps, have fun
| Thread Tools | |
| Discussion New EPP Super Zoom 4D from SoaringUSA.com build thread | hybris | 3D Foamies | 2467 | May 09, 2012 08:24 PM |
| New Product New Super Zoom 4D EPP | rcmann | 3D Flying | 127 | May 31, 2008 03:26 AM |
| Sold New Super Zoom 4D (blue) | crazy pilot | Aircraft - Electric - Airplanes (FS/W) | 2 | Dec 27, 2006 06:43 PM |
| Discussion NEW "Super Zoom" with floats | donjiskra | Waterplanes | 2 | Sep 18, 2006 09:05 AM |
| Discussion the best CG for Super Zoom 4d from Hacker | swiart2 | 3D Flying | 1 | Jun 25, 2006 12:02 AM |
