United States, MA, Waltham
Joined Dec 2001
How much area does it have? Might be good to have the relevant Reynolds numbers in hand when making the evaluation. When the Re goes up, thicker airfoils have less of a performance penalty, in general.
Approximate rules of thumb for Re: -speed in feet per second at wing Cl of 1 is about 7 times the square root of the wing loading in ounces per square foot, but I seem to recall maybe it's more like 7.3 - Re is something like 532 times the chord in inches times the speed in feet per second -actual Re in steady flight will be proportional to one over the square root of the Cl In addition to the Reynolds number effect, the max lift coefficient desired is different depending on the aspect ratio. If you have an aspect ratio of 8 (very low for something this size), then you don't need as much as if the aspect ratio was 18 or 20. IF you go to a CL of 1 on a wing that has an AR of 8, you will have a lot of induced drag. For recreational use, I would imagine this airfoil would be fine on something so large, assuming everything else about it is good. |
Latest blog entry: pics from Winthrop, MA indoor flying...
Joined Dec 2001
S-4083's performance in a Climmax doesn't tell you a whole lot about how it would be in something MUCH larger. The 4310 is thicker and therefore better structurally. The 4233 is even better structurally. On these larger gliders, there is less of an aerodynamic penalty for the thicker foils.
If I had Profili working again I could give you more specific info. |
Joined Dec 2001
I'm not saying that the 4083 wouldn't work, just that you can't tell from a small model.
I had a Wizard many years ago. It was a 2 meter RES, or maybe just RE. It had a thin, flat bottomed airfoil that was considerably faster than the usual ones. |
! I am thinking about the Kranich from SMC Gerten (Kranich = crane). Cheers, Tom |
Joined Dec 2001
Just make sure it doesn't have the shrunk tail disease. Many gliders have v-tails that are too small.
For this very high aspect ratio glider, with a moderately high wing loading, the 4310 may be better than the AG foils, because it has a higher lift coefficient. I think if we can believe the plots that jrs123 provided, it may be a decent performer. The thickness will help structurally on such a long skinny wing, though really it ought to be thinned out along the span so that it is relatively thin at the tips. |
atmosteve, contribute instead of complaining
"atmosteve", if you write at least 2-3 posts more than "lincoln", (preferably sarcastic and malicious) then you catch him within 1 year in the number of posted messages. For it seems to be the only reason that you post.
But, unless you have something useful to the discussion, I think, however, that you can keep quiet. Excuse the rest of you that I did not add anything to the topic, but I think it seems like atmosteve has other intentions than to be helpful in threads that he participates in. /Ville
| Thread Tools | |
| Discussion Airfoil wings from Depron | Lockey | Foamies (Scratchbuilt) | 27 | Jul 28, 2012 09:38 AM |
| Discussion Request good airfoil for slowflying rubber powered Peanuts | Dinser | Modeling Science | 25 | Jul 07, 2012 12:45 AM |
| Discussion Clark-Y Airfoil Ordinates | charlie01 | Modeling Science | 8 | Mar 15, 2012 02:21 AM |
| Question Clark-Y Airfoil Ordinates | charlie01 | Foamies (Scratchbuilt) | 8 | Mar 08, 2012 06:04 AM |
| Discussion Airfoil cross section? | I_AM_Chewbacca | Foamies (Scratchbuilt) | 7 | Feb 23, 2012 08:24 PM |
