Old Apr 06, 2014, 07:46 PM
May the Wind Always be Good
Webster, Minnesota
Joined Feb 2007
Winch Line
Working on getting some better line for my Winch ..Looking for what size , and where to get...post here or PM me ..Thanks ..Mr. Kite....
Mr. Kite is online now Find More Posts by Mr. Kite
Old Apr 06, 2014, 09:31 PM
LI, New York, USA
Joined Mar 2003
I get my wing line and the line for the club at Memphis net and Twine
https://www.memphisnet.net/category/...tebraidedseine
For personal or club use I would recommend #21 if you are mostly 2M or woodies. If you are flying mostly composite ships then #24. I have #24 on my winch.
For active contest use I would use #24 or #30.
I think the Eastern Soaring League has used #30
I have #9 on my retriever.
aeajr is offline Find More Posts by aeajr
Old Apr 07, 2014, 06:57 AM
Maryland
Joined Dec 2002
The Fish Net Company @ 800-256-5256
http://www.fishnetco.com/products/twine/twb
rc4fun is offline Find More Posts by rc4fun
Old Apr 07, 2014, 11:41 AM
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
I have more than a few rolls of this that I can sell.
It is from Samson Rope Co.
It's a continuous 2lbs worth of 300lb line.
$22 each plus shipping. I've tried and tested many types of line, these are the most consistent and one of if not the best in my opinion.
fnnwizard is offline Find More Posts by fnnwizard
Old Apr 08, 2014, 06:54 PM
3D Toy Designer
MicroRotors's Avatar
USA, CA, Hesperia
Joined May 2001
I'm making a winch and wanted to know, is this worth trying?
http://www.ebay.com/itm/100-ft-750lb...-/171154688770
Bill
MicroRotors is offline Find More Posts by MicroRotors
Old Apr 08, 2014, 10:21 PM
LI, New York, USA
Joined Mar 2003
$19 for 100 feet X 12 for 1200 feet of line (600 out and 600 back)
That would be $228, assuming you only use 1200 feet. FWIW, LSF limt is over 900 feet for LSF tasks. that would take 1800 feet of line or $342.
Or you can buy regular winch line for about $15 or $20 for 1200 feet or $30 to $40 for 1800 feet. Rough round numbers.
Your call.
Old Apr 08, 2014, 10:28 PM
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
Not to mention, 750# Kevlar will have zero stretch. I'd also worry about it's ability to quickly sever anything that gets caught on the line.
Wazmo is offline Find More Posts by Wazmo
Old Apr 09, 2014, 12:40 AM
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
What Wazmo said...!!! I used 225# dacron... once. If you use line with no stretch, you had better be ready to throw the glider the instant you touch the pedal. If not it will be ripped from your hand... See above and you'll know how I know...
schrederman is offline Find More Posts by schrederman
Old Apr 09, 2014, 08:18 AM
LI, New York, USA
Joined Mar 2003
Very good point about the stretch Nylon has some stretch which allows you to tension the line before release. For light models you only tension a little. For high end composite models you tension a lot.
For F3J they don't use braided nylon they use monofilament which REALLY stretches and that stretch is part of the launch power.
So, the advantages of nylon for cost and for character are well established.
BTW, no matter what you use you really need to throw the glider. That was always drummed into me as I was learning. This weekend it paid off. I was launching my Supra. Tensioned up the line and threw. A second later the line broke. No idea why but the glider was already turning nose up when it happened.
Fortunately I had thrown it enough that it had sufficient forward air speed for me to control it and land it safely. If I had just let the line take it out of my hand it would have likely crashed.
Old Apr 09, 2014, 12:14 PM
3D Toy Designer
USA, CA, Hesperia
Joined May 2001
I wouldn't use a line that was completely Kevlar. I was thinking 50 past the turnaround and I would add Nylon line for the stretch 50 feet from the parachute on out. The Kevlar would be mainly in the high stress area of the line.
This past weekend, I had the line break on my launch, about 10' out. Since I just started TD and I am new to a winch, throwing is something I need to work on. Anyhow, I came down on the left wing tip, followed by the nose and then the left wing tip.
I got lucky, ... no damage, however, ... I did learn a valuable lesson!
THROW IT!
Regards
Bill
Old Apr 09, 2014, 12:43 PM
the flying is good
dephela's Avatar
USA, CT, Hamden
Joined Oct 2002
Leave the Kevlar off completely! No stretch at all, the fifty feet of nylon won't have enough stretch to notice.
dephela is offline Find More Posts by dephela
Old Apr 09, 2014, 04:08 PM
Joined Nov 2002
It is often the knots used that cause line breaks. Look up Knot Wars online and select knots that have the highest percentage of line strength...
Old Apr 09, 2014, 04:33 PM
3D Toy Designer
USA, CA, Hesperia
Joined May 2001
Bimini Twist Knot, ... the main knot used in catching monster Marlin and Tuna, ... 2 things that can easily out-pull any winch launching an RC sailplane.
Old Apr 10, 2014, 10:39 PM
Joined Nov 2002
Thanks, I'll look that one up...
Old Apr 23, 2014, 10:39 AM
Webster, Minnesota
Joined Feb 2007
Goodwinds
I got some line from here and it looks like 1st class line ...Have used it yet ...I will post my findings on it in a week or too....https://goodwinds.com/line-winders/braided-dacron.html
Discussion Winch Line schrederman Sailplane Talk 9 Mar 31, 2014 11:05 PM
Discussion Winch line leader + ring? SoaringDude Sailplane Talk 10 Mar 09, 2014 11:59 PM
Question How do you line up your winch with the winch line? satinet Multi Task F3X 8 May 16, 2013 04:41 PM
Question How to attach winch line to new winch? slozuke Sailplane Talk 10 Jul 25, 2008 02:04 AM
What works well for winch line? tempest411 Thermal 9 Aug 04, 2002 06:57 PM
