Old Jan 28, 2014, 09:20 PM
Joined Jun 2012
Hi guys,
after a while away from the sunracer after a failed maiden, i re-maidened it today. flys well except i am having to provide massive amounts of up elevator and im maxed out on my trim setting. With full throttle it will fly straight as an arrow (with some sub trim), however as soon as i glide it will want to drop like a rock. I am having to continually pull up elevator with out the motor on.
I know its not a glider, but surley it can glide better than what its doing now. Is this normal?
I started with my CG at 45 and eventually moved it back to almost 50mm, still had the nose dropping without any throttle.
I did notice the back of my wing does not sit flush against the back part of the fueselage opening (where the back screw goes in). Elevator seems to be fixed in place fine, cant see anything wrong there.
any tips or info would be greatly appreciated!
thanks
Alex
ahunter852 is offline Find More Posts by ahunter852
Old Jan 29, 2014, 02:12 AM
feefo's Avatar
Staffs, UK
Joined Apr 2009
Your wing needs to sit flush, find out why it's not, maybe the wiring / all the stuff you have in there is the problem and stopping the wing seating properly..
feefo is online now Find More Posts by feefo
Old Jan 29, 2014, 09:21 AM
United States, WI, Fond du Lac
Joined Sep 2011
I agree your wing needs to sit flush. It may be acting like on big spoileron thus slowing it down and dropping the nose. Just a theory but get that wing flush then fly but an see what happens.
racerboy65 is offline Find More Posts by racerboy65
Old Jan 29, 2014, 09:27 AM
Joined Jun 2012
Turns out the nut wasn't sitting flush against the top of the back end of the fuselage opening , took it out and epoxied it in nice and flush. Wing seems to fit much better now. Will test fly next week hopefully.
Thanks for the help!
Old Jan 30, 2014, 10:49 AM
Hi speed plane affictionado
S_E_V's Avatar
United States, NY, Wurtsboro
Joined Aug 2013
greeting everyone . can someone help me out here .
I have a HET1w30 and want to run it on a 2s battery can someone here tell me what prop amp draw ,watts and more or less speeds I will be looking at . I want to run it in a rifle 1m .there isn't any info over there
thanks
S_E_V is offline Find More Posts by S_E_V
Old Apr 14, 2014, 11:47 PM
Joined Apr 2014
hi guys, i have my eye on the sunracer V4 and i have a supplier of HET motors near by,
so am wondering what HET motor will get me to 300kmh or around 190mph
i am looking at the 2w20 on 4s but i am worried about heat issues as its only rated for 60Amps and i would imagine it will need to be pushed past 80 amp to achieve my speeds.
has anyone tried the 1w40 on 4s? it is a 3300kv motor weighing at 180g
any help will be much appreciated
regards,
Ampsan.
Ampsman is offline Find More Posts by Ampsman
Old Apr 15, 2014, 02:54 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
the 1w40 will be over 100amps on 4s with a 4.7 prop, So if you esc and lipos can handle it, go for it
It will probably take you to 190mph.
sebbe is online now Find More Posts by sebbe
Old Apr 15, 2014, 03:07 AM
Joined Apr 2014
cheers think i will go towards that motor but im just worried about that extra weight, 180grams is 35grams more than the recomended 1112/2D neu at 145g (on espirit model)
wonder what difference to launching and landing that will make
regards
Old Apr 15, 2014, 03:20 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
35 grams is nothing to consider a problem
Old Apr 15, 2014, 03:24 AM
feefo's Avatar
Staffs, UK
Joined Apr 2009
I wouldn't think it'd balance, my V2 had a little ol' 16-15-3 on 3s 2200 and I don't remember much room to move that battery back. 35g in small models can be a lot. Lead in the tail would work though. I could be wrong and it might balance out ....
Old Apr 15, 2014, 03:45 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
feefo could be right, balance is another issue for sure, I was just meaning the extra weight itself will not be a problem, balanceissues is another thing
Old Apr 15, 2014, 04:03 AM
Joined Apr 2014
ahhhh right thanks guys
ok well i think ill have to get the plane and then try putting a 180g weight where the motor is and try balance it out with my lipo
but i have seen somewhere in this forum that someone said the v4 manual says to use the neu 1112/2d and a 4s 2600 for max performance
ill be using a lighter 2200 4s hmmm
Old Apr 15, 2014, 06:32 AM
feefo's Avatar
Staffs, UK
Joined Apr 2009
A lighter lipo is not always going to help, you might need more weight aft of the CoG to help counter balance the heavier motor.
Old Apr 15, 2014, 07:07 AM
Joined Apr 2014
ah right true true, oh and will run two 2s 2200 packs in series so im a little bit more flexble
looks like i need to buy this sucker and start CoG testing
thanks for the help guys
Question SunRacer II Questions/build pics TaSaJaRa High Performance 480 Aug 21, 2011 10:34 PM
New Product New Sunracer V3 n-2-stuff High Performance 6 Aug 19, 2010 10:58 PM
Poll Build Off III: What to build??? W@CC0 Scale Kit/Scratch Built 17 Sep 11, 2008 07:51 AM
Sunracer Build Questions nrthwing High Performance 8 Nov 27, 2005 06:56 AM
Sunracer build questions jimlang High Performance 4 Oct 21, 2005 02:22 PM
