Old May 30, 2012, 05:57 PM
Joined May 2010
2.4 gig radio glitch
I was at our field today my friend and I were flying a Sig Senorita and an Eratix.After two to three good flights, I took off with the Sig and appprox. 20 seconds into the flight the plane shut on ,no throttle or controls. I pulled the throttle back to off and powered back up and was able to land. My friend took off and at approx the same spot his did the same thing with plane ending results. After gathering up the pieces I put a new battery in the Sig and took off at about the same spot I had a compete engine and controls failure. It was as if the reciever completely shut off. I checked the batt and it showed 4.07 on all cells. Has anyone heard of interferance on 2.4 GHZ. I can't figure out what would cause two planes to have the same problem within 15 mins of each other with trash can results. If anyone has heard of this please let me know, Thanks, Jim
utah jim is offline Find More Posts by utah jim
Old May 30, 2012, 09:28 PM
Ohio
Joined Nov 2003
What is the radio? Spektrum will not do that, or Futaba or JR.
The $30 systems I would worry about. Single rcvr. No diversity.
jglenn is offline Find More Posts by jglenn
Old May 30, 2012, 10:42 PM
Joined May 2010
Both tx and rec. are spectrum dx6 and 6110 rec.
Old May 31, 2012, 01:04 AM
Joined Apr 2011
Well, this is spektrum DSM2, not DSMX and the spektrum selects two channels that are free *at the moment* and then sticks with it. So there's a potential that a change in the RF environment causes a failsafe.
Other than that, doesn' t look like that's the problem here. This is the spektrum page about the AR6110: http://www.spektrumrc.com/Products/D...odId=SPMAR6110
** The AR6110 receiver is not compatible with the DX6 park flyer radio system.
radialmind is offline Find More Posts by radialmind
Discussion Futaba "Gold Case" Radio Conversion to 2.4 gig challenger_i Radios 28 Dec 17, 2011 07:15 AM
Discussion Will a 2.4 gig tx/rx interfere with a 2.4 gig downlink? Buzzncuzz Multirotor Talk 18 Jun 10, 2011 03:45 PM
Discussion 2.4 Gig version of venom radio? you tell me? BACKEMFNRG Motorcycles 11 Jul 27, 2009 01:05 AM
Discussion 2,4 gig RC and 2,4 gig eagletree seagull Heli-Peter Eagle Tree Systems 1 Sep 01, 2008 10:53 AM
