Old Jun 23, 2015, 10:06 AM
Rum Runner is offline
Find More Posts by Rum Runner
Rum Runner's Avatar
Canada, ON, Ottawa
Joined Aug 2012
Sonic Modell Sbach 342 Balsa Electric ARF 48"
Hello all
I received a Sonic Modell Sbach for fathers day. I am wondering if anyone else has heard of this plane?
http://www.greathobbies.com/producti...rod_id=SNM2900
I will document the build with pics here.
I will be setting it up more as a sport flyer to begin with as I have never did any 3d flying yet.
Originally I am thinking about using a Turnigy D2836/8 1100KV Brushless Outrunner Motor on 4s.
Motor is 70g and I have an assortment of 4s 1000 to 2800mAh batteries from about 100g to 300g aprox. I'll see if it fits and if I can get it to balance with this motor. I'm sure it will fly basic pattern no problem with this set up and thrust should be around 1:1.
I thought this model was a foam over balsa model but I unpacked it last night and it is a balsa/film model.
Once I get it built and see how it flies , AUW etc and get some more stick time I'll see about getting a motor to switch over to 3d flying.
Cheers,
Paul
Rum Runner is offline Find More Posts by Rum Runner
Old Jun 25, 2015, 11:53 AM
Rum Runner's Avatar
Canada, ON, Ottawa
Joined Aug 2012
Instructions with kit CD pdf
Hey all,
I should have some pics up today.
The kit came with a CD with a PDF file for the instructions. it is 18 mb( to large to attach) so I'll just do a few screen shots of a couple of pages for now.
I'll add some pics of the actual model and anything of note.
Cheers,
Paul
Old Jun 25, 2015, 12:40 PM
Rum Runner's Avatar
Canada, ON, Ottawa
Joined Aug 2012
I just noticed the manual says 1650g and Great Hobbies web page says 1191g (42oz).
I will weight up all the parts and caclulate roughly what the AUW will be. If it is close to 1650 then for sure the Turnigy D2836/8 1100KV (on 4s) will probably be to small ...
Cheers,
Paul
Old Jun 25, 2015, 09:27 PM
Rum Runner's Avatar
Canada, ON, Ottawa
Joined Aug 2012
I quickly test fitted all the parts and all goes together very nicely.
The wing is joined by a double spar and fits nice and snugs up the last 1/4". Nice! A couple of hooks and rubber band keep the wings from separating and should be more than adequate.
I weighed up the plane with all the hardware minus radio and motor gear. Weight was 1050g.
My 28/36 motor may be a bit small but I will try to see how it fits for now.
Motor = 70g
ESC = 23g
Servos = 10g x4 = 40g
Battery 4s = aprox 100g for 1000mAh - 215g for 2200mAh
Prop = 40g(guess)
My AUW should be around 1320g w/o batt. = 1420 to 1535g.
For sure I will need more power for 3d.
I am hoping the 28/36 will be good for learning at my level of flying, perfecting basic pattern and rudder co-ordination stuff.
Cheers,
Paul
Old Jul 01, 2015, 09:57 PM
claudioconstruct is offline
Find More Posts by claudioconstruct
Joined Mar 2015
i have same plane
I have the same plane . Got it at the same time. Mine went together well . People at my club said using rubber bands are risky so I'm using zipties. I put 35 900kv on it but haven't flown it yet.
claudioconstruct is offline Find More Posts by claudioconstruct
Old Jul 01, 2015, 10:05 PM
Joined Mar 2015
i have same plane
I have the same plane . Got it at the same time. Mine went together well . People at my club said using rubber bands are risky so I'm using zipties. I put 35 900kv on it but haven't flown it yet. It is tail heavy so i had to add weight in nose and i'm going to use 3000mah battery.
Old Jul 06, 2015, 02:26 PM
Rum Runner's Avatar
Canada, ON, Ottawa
Joined Aug 2012
I've been away on holidays.
Did a quick check and looks like the little 28/36 will fit perfect.
Hoping to have together in next few days.
Hopefully will not be tail heavy with battery all the way forward.
Cheers
Old Jul 17, 2015, 09:20 AM
madmaxx01 is offline
Find More Posts by madmaxx01
Joined Jul 2015
caution
Hey guys I also have the same plane and had some serious issues with the C of G they recommended. bring the C of G forward at least 1/2" . After a very scary first flight i moved mine forward and it was fine after .
madmaxx01 is offline Find More Posts by madmaxx01
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 02:36 PM
New Product Future Model 48" Scale Sbach 342 EPP - kits are now available!!!!! groovejet 3D Foamies 223 Dec 14, 2014 01:49 PM
Build Log Flight Model Sbach 342 (ARF balsa) FlyDave Sport Planes 55 Dec 12, 2012 06:38 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 06:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 01:02 AM
