Old Jun 01, 2015, 11:10 PM
waytooslow is offline
Find More Posts by waytooslow
Crash 'em if you got 'em
waytooslow's Avatar
United States, TX, Euless
Joined May 2013
DX9 elevator trim switch dead?
Anyone else had a trim switch fail? my up elevator trim stopped working today, can trim down all day, but no go on up.
Guess I have to send in, of course its prime flying weather the next full week, well except for all the flooding in Texas.
Andy to the rescue?? any thoughts?
waytooslow is offline Find More Posts by waytooslow
Latest blog entry: Top Flite P40 .60 is no more
Old Jun 01, 2015, 11:13 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
Pretty common occurrence on TX's. Just replaced a Taranis switch for a guy. It was pretty well plug n play. No soldering.
I did a search, saw a video just replacing the plastic toggle with aluminum on a DX7 and if similar you don't want to DIY!
4*60 is offline Find More Posts by 4*60
Old Jun 01, 2015, 11:36 PM
waytooslow's Avatar
Joined May 2013
true -- but still under warranty i think - - I am sure HH will make good, just going to be crappy that I have no TX while waiting.
Old Jun 02, 2015, 08:03 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Why hesitate? Get it in the morning mail!
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jun 02, 2015, 08:38 AM
waytooslow's Avatar
Joined May 2013
thought maybe a reboot -- Thanks all powerful Andy! -- Can I transfer all my models to a DX6 if I pick up a back up? I assume a not so fast turnaround
Old Jun 02, 2015, 01:38 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Recent turnaround is found on the web page. Right now it says 5 days.
http://www.horizonhobby.com/content/...service-center
The DX6 will support DX9 unless you have uncommon tail types. Normal models will come straight across.
Andy
Site Sponsor
Old Jun 02, 2015, 09:44 PM
waytooslow's Avatar
Joined May 2013
big thanks to freechip
Turn On the TX in RAW INPUT mode by holding down both BACK & CLEAR buttons while powering On, powered off and the back on in normal mode - Trim worked.
Old Jun 02, 2015, 09:46 PM
waytooslow's Avatar
Joined May 2013
Andy
Thanks Andy -- I opened a RMA -- hope it does not mess up that its is not heading to shop at least not for now.
Old Jun 03, 2015, 05:31 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
@ waytooslow - my suggestion is NOT a fix but rather a method/tool to check if mechanically the switches are working, if they mechanically work then you have to assume it's programming hence why I said to you
If it didn't work in the Raw Input screen - have the radio service
if it did work in the Raw Input screen - Reset the model memory...
freechip is offline Find More Posts by freechip
Old Jun 03, 2015, 09:39 AM
waytooslow's Avatar
Joined May 2013
free chip -- it may have been coincidence, but switch is working either way. I did shoot a little blue shower in the switch afterwards and a little air to dislodge any funk.
Thanks for clarification
Old Jun 03, 2015, 09:43 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
That's all I was trying to do "clarify" don't want folks to think accessing this Menu will fix things, it's just a tool to help test the mechanical side of things.
Old Jul 29, 2016, 06:28 PM
Depronicus is online now
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
My DX9 throttle trim started acting up a couple of weeks ago. "On" direction worked, but "Off" was intermittent or wouldn't work at all.
Upon opening the case, I was appalled at how much grass and fine dirt fell out. How did all that stuff get into it? Through the gimbal opening?
I tapped and shook it, and blew out all I could, reassembled it, blew into the throttle trim as hard as I could, rebooted, and the trim works fine now.
Try this if you have a trim giving you trouble. It may just be dirt.
Depronicus is online now Find More Posts by Depronicus
Mini-HowTo Jeti DC16/DS16 Flaps on 3 position switch with separate elevator trim. wfield0455 Jeti USA 45 Jul 07, 2015 04:24 AM
Discussion FS TH9X Elevator to Knob for faster Trimming? Emmanuel2000 Radios 0 Dec 19, 2014 11:11 PM
Discussion Futaba 8FG dead trim switches fix. elkski Hand Launch 0 Sep 13, 2014 02:40 PM
Discussion Futaba 8FG dead trim switches fix. elkski Hand Launch 0 Sep 13, 2014 02:37 PM
Idea Thoughts on elevator trim and saving your dead-stick behind Boidster Beginner Training Area (Aircraft-Electric) 34 Sep 11, 2008 02:02 PM
