It used to be gyro gain before flybarless heads. Now it's nothing.
Latest blog entry: Some stuff
I have often wondered why they needed 6 channels and how it got started. Really, you only have 2 sticks and 4 functions you control in flight. Pitch is simply a function of throttle settings. There are several CP helis (Blade MCPx and Hirobo Quark SG) that only need 4 channels as the onboard flight control board is perfectly capable of handling pitch. In the old days, the transmitter mixed pitch because there was no onboard intelligence. But, that still leaves a lot unanswered. Admittedly, my knowledge doesn't go back more than about 10 years.
A buddy of mine has a big beautiful scale Agusta A-109. Mechanics are a Raptor 50 (?) converted to electric. This was "before" eCCPM so the swash mixing is done mechanically. The servo layout, mixing arms/plates, etc., is truly a fascinating piece of engineering. And I thought eCCPM and a flybarred head was complicated. In his case he still uses Ch.5 for a tail gyro because he has an early FBL controller that was only a 2-axis gyro.
Technology in our toys is truly amazing. |
Latest blog entry: Chaos 600 ESP build
Someone correct me if I'm wrong, but the servos working together on a swashplate is called CCPM, or Cyclic Collective Pitch Mixing. The three servos work together to move the swashplate for both Cyclic (aileron/elevator) and Collective Pitch (pitch of the blades). Make sense? |
Larger FBL helis will have a FBL controller that sits between the receiver and servos. It's a separate unit. Smaller FBL helis like the Blade line from Horizon will have the receiver and FBL controller as one unit.
The gyro is misnamed in a flybarless heli. It's really a flight controller with a 3 axis gyro built-in. Depending on which flight controller you bought, it could also contain accelerometers, barometer, magnetometer, GPS and other sensors. But, that can get rather expensive and you will wish you had more than 6 channels before long.
| Thread Tools | |
| For Sale Heli-Max TX610 2.4GHz 6-Channel Transmitter - Mode 1/Mode 2 - Axe 100 CP | rawr404 | Aircraft - General - Radio Equipment (FS/W) | 6 | May 14, 2013 07:28 PM |
| Walkera Genius CP V2 Rechargeable 6-CH Radio Control Helicopter - DEVO 7 - Gyro | dealextremefan | DealExtreme RC | 0 | Apr 21, 2013 09:09 PM |
| Discussion 6 channels heli : what are the 6 channels ?? | Rollmops67 | Electric Heli Talk | 13 | Oct 05, 2012 05:46 AM |
| Discussion Real Flight sim are all the helis 6 ch? can u run 4 channels? | peelot | Simulators | 2 | Dec 21, 2008 04:49 PM |
| Question What are the differences between 4,5, and 6 channel helis? | Mr. Pimp | Micro Helis | 5 | Dec 29, 2006 11:15 AM |
