Old Apr 30, 2016, 06:24 PM
GuySmily is offline
Find More Posts by GuySmily
United States, CA, Sacramento
Joined Jul 2013
Can't Install PL8 CCS - install log shows 404 error
Hey all,
Does anyone have some kind of offline installer for PL8 CCS?
I can't get CCS to install - it fails with the following error:
Excerpts from the install log:
Code:
ERROR SUMMARY
	Below is a summary of the errors, details of these errors are listed later in the log.
	* Activation of http://revolectrix.com/applications/PowerLab8v2_Software/CHGM8Sv2.application resulted in exception. Following failure messages were detected:
		+ Downloading http://revolectrix.com/applications/PowerLab8v2_Software/Application Files/CHGM8Sv2_1_2_0_243/CHGM8Sv2.exe.deploy did not succeed.
		+ The remote server returned an error: (404) Not Found.
I sent an email to support about this but haven't heard back all week, so hopefully someone here can help.
Thanks!
GuySmily is offline Find More Posts by GuySmily
Old May 01, 2016, 07:30 AM
JMynes is online now
Find More Posts by JMynes
Joined Jan 2015
Me too. It was working, then it stopped. Uninstalled and unable to reload.
JMynes is online now Find More Posts by JMynes
Old May 01, 2016, 07:11 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
Sorry about inconvenience. Revolectrix is already aware of this issue and is working on it. No ETA at this time.
Gregor99 is offline Find More Posts by Gregor99
Old May 03, 2016, 02:45 PM
GuySmily is offline
Joined Jul 2013
Thanks for the update. Eagerly awaiting more news.
Old May 06, 2016, 01:00 PM
Gregor99 is offline
Seattle
Joined Sep 2007
The issue is now resolved. The Powerlab8 CCS should install as expected. Let me know if you run into any issues. Thanks for your patience in this matter.
Old May 06, 2016, 06:26 PM
Joined Jan 2015
Yep, it works now.
Old May 06, 2016, 09:02 PM
GuySmily is offline
Joined Jul 2013
Confirmed. Thanks for getting us back online!
To others having this issue: You also may need to redownload setup.exe (see: http://www.revolectrix.com/new_appli...ftware_v2.html)
Old May 12, 2016, 12:03 PM
JohnWilliamson is offline
Find More Posts by JohnWilliamson
Joined May 2010
Except that someone has uploaded the OLD version CCS Software.
That link on the main site gives us an OLD version.
The pre-LiFe (LiFePO4) A123 fix version. As such it is missing the newer pre-sets, and the various limits that were fixed / updated are back to the ones we had many months back. EG 3.3V balance only etc...
Can someone take a look please!
JohnWilliamson is offline Find More Posts by JohnWilliamson
Old May 12, 2016, 06:44 PM
Joined May 2010
In the meantime, here's the latest one, that has vanished. This has the fixes, extended voltages and higher starting voltage for balance and wider voltage limits before it slaps your wrists with a "safety charge" on LiFe (A123) and the other missing pre-sets etc. zipped.
Unzip it to your desktop - its in a folder called FMA. Run it directly, or make a shortcut. As a temporary measure. It works ok, at least for LiFe batteries. Still needs a lot of other stuff sorting out though! But I am not allowed to mention that.
http://www.wheelchairdriver.com/software/FMA.zip
Old May 13, 2016, 05:24 AM
steves1977uk is offline
Find More Posts by steves1977uk
United Kingdom
Joined Jan 2015
I wonder how many issues like this go unreported? I think I was the first to notice this...
Steve
steves1977uk is offline Find More Posts by steves1977uk
Old May 13, 2016, 07:11 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Update: The latest version that includes the LifeP04 balance changes has been re-uploaded to the servers. Please use add/remove the existing copy you have an re-install from:
If your browser reports installation errors, clear your browser cache including:
Browsing history
Download history
Cached images and files
Hosted app data
Old May 14, 2016, 02:58 PM
Joined May 2010
Old May 14, 2016, 03:36 PM
United Kingdom
Joined Jan 2015
Thanks for fixing this
Steve
Old May 15, 2016, 05:21 AM
Joined May 2010
Its a different size/version again. Newer than the one that disappeared. Any idea what else has changed?
Old May 15, 2016, 05:03 PM
Gregor99 is offline
Seattle
Joined Sep 2007
The CCS and firmware were not changed. The developer republished the most recent version which includes the latest changes such as the LifeP04 balance start at 3.5v. As part of that process, file versions and dates may get updated, but the content hasn't changed.
Again, sorry for the trouble. If you have not un-installed the current version and re-installed the current version please do so, even if what you have is still working.
Rant Can't log in to the store to check order status TWSC HobbyKing 6 Oct 11, 2015 10:29 AM
Discussion PL8 and CCS questions Roblister FMA Direct 4 Oct 25, 2013 07:08 PM
Discussion Can't Download CCS PL8 Firmware (even PL6) pp32789 FMA Direct 29 Aug 26, 2012 01:43 PM
Question PL8 CCS - internal resistance lktroiani FMA Direct 6 Feb 16, 2012 08:05 PM
Discussion PL8 CCS Pack Voltage Graphing Error Costas_ FMA Direct 5 Dec 20, 2010 08:58 PM
