Old Apr 13, 2016, 06:07 PM
grant31781 is offline
Find More Posts by grant31781
Joined Jun 2003
How much power does an RC gyro need to fly level
I am trouble shooting my motor that is getting very hot on my gyro so I connected the watt meter to the gyro and took it for a flight!
Weight 16.2 ounces up to 19.4 with Watt meter on board.
38 inch rotor hot wire foam blades with CF leading edge. Disc loading 2.46
Peak watts 133.6/ 11.84 amps peak
Data for flying a level circuit with about 1/2 throttle. Including climb out and a few climbing turns. Wind about 10 mph
Flight time 4.5 mins
Average amp draw 6.7
Average watts 76
Volts min 10.78
After this flight the motor was too hot to grab. It even had a hot smell.
grant31781 is offline Find More Posts by grant31781
Old Apr 14, 2016, 10:43 AM
rus1 is offline
Find More Posts by rus1
United States, AZ, Phoenix
Joined May 2003
We had this same problem with hot motors until we realized the motor is working harder than it would on a fixed wing model due to drag from the rotor system. We think of it as pulling a trailer with a car. The engine must work harder.
We solved the problem by using motors in a higher wattage class.
This is the motor I use on my Scout from Flying Balsa:
http://www.hobbyking.com/hobbyking/s...trSearch=D3542
It is in the 600 Watt class, it is inexpensive, has more than enough power, and doesn't get hot.
Cheers!
Russ
rus1 is offline Find More Posts by rus1
Question How much preparation does a car need? Don Promillo Car Talk 20 Mar 01, 2016 07:30 AM
Discussion How much power can i suck from an AR-6XXX servo connector? fabersum Scratchbuilt Indoor and Micro Models 2 Oct 10, 2015 09:58 AM
Question How much power does a GA006 charger for Walkera Ladybird draw? Steve_in_NJ Micro Ready-to-Fly 0 Apr 19, 2014 05:25 PM
Discussion How do you know how much wing span is needed for the aircraft to fly ? jenorm1497 Modeling Science 18 Nov 27, 2013 09:05 PM
Discussion Wireless Video Power Levels ... How much power do you need ??? JettPilot Aerial Photography 5 Dec 21, 2006 01:05 PM
