Old May 24, 2015, 12:04 AM
jackosmeister is offline
Find More Posts by jackosmeister
Non Eius A Stupri Fucus
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
the stock wing has some incidence built into it, reflex artificially removes that as you are effectively lowering the angle of attack of the wing. Less lift being produced, less drag. When you bank, and then yank, you dont want reflex anymore as turning is much more efficient with the higher angle of attack, so snap flap does that.
Its used more on gliders than anything, stuff like F3F, when normally snap flap drops the TE below the nominal point, but since the voodoo has a higher AOA out of the box just returning the wing to "stock" works perfect as its setup to turn on a dime anyway.
The incidence is perfectly fine for most speeds, and the voodoos will out turn near on anything, remember it was designed for a brushed 400 motor!
jackosmeister is offline Find More Posts by jackosmeister
Old May 25, 2015, 08:09 AM
gas op de lolly is offline
Find More Posts by gas op de lolly
The Netherlands, OV, Deventer
Joined Jul 2007
Did an other 4 flights
Man this is so much fun and so scary at the same time.
Just need to fly it a lot more to get some real confidence i would say, but with only 3min. flight time it will take a lot more flights before i will fly inverted 3Ft above the field
i really can't believe you guy's are pushing it even faster then it is a already on the "stock Höllein" setup. Respect!!
gas op de lolly is offline Find More Posts by gas op de lolly
Old May 28, 2015, 05:58 PM
XtremeWingRC is online now
Find More Posts by XtremeWingRC
Fast? I got something 4 ya!
XtremeWingRC's Avatar
United States, WI, Oak Creek
Joined Oct 2007
Little voodoo fun with jsteil1098 (jim) at the sod farm today
Mega 16/15/2
3s 1300 70C Thunder Power Magna series
Dymond 47s servos for ail
futaba s3154 for elev
4.2x4 apc prop
Shes rips!! Havent flown a pylon since 2008. I had a VIP-1, and Escape pylon from soaring USA back then. Geez has it been really 7 years since ive flown pylon planes. Well my flying was a really rusty. Forgot how these babies turn so sharp.
ill get better for sure.
Voodoo Pylon racer at SOD FARM (8 min 18 sec)
XtremeWingRC is online now Find More Posts by XtremeWingRC
Old May 29, 2015, 01:41 AM
Joined Oct 2007
you got that right, scary and fun!
Old Jun 07, 2015, 10:12 PM
Joined Oct 2007
Some more voodoo flying this weekend
Still trying to get used to her. This time she was rising again too high, got trim her down some more.
Casey flying the VOODOO (3 min 7 sec)
Old Jun 13, 2015, 12:47 PM
Jezzejamez is offline
Find More Posts by Jezzejamez
Jezzejamez's Avatar
United States, MI, Commerce Charter Township
Joined Oct 2013
http://youtu.be/Fb3qseIreX8
Keep banging those sticks, great job. I miss my voodoo. Maybe I'll grip another
Jezzejamez is offline Find More Posts by Jezzejamez
Old Jun 14, 2015, 09:38 AM
Joined Oct 2007
Did more flying at the sod farm on saturday
Im definately getting better.
Enjoy
U can here the swoosh the prop makes when it windmills
VOODOO Pylon Action FAST laps (4 min 37 sec)
Old Jun 29, 2015, 04:53 PM
feefo is online now
Find More Posts by feefo
#This year's weather sucks
feefo's Avatar
Staffs, UK
Joined Apr 2009
Here's 2 inflight screen shots of my 16-15-2E F5D, 3s 1400, DUP's 4.7 x 6.1 folder,
feefo is online now Find More Posts by feefo
Old Jun 30, 2015, 02:38 PM
hybris is offline
Find More Posts by hybris
hybris's Avatar
Houston, TX
Joined May 2003
Where does one get an over square small folder?
hybris is offline Find More Posts by hybris
Old Jun 30, 2015, 03:00 PM
hubcapsteve is online now
Find More Posts by hubcapsteve
United States, CA, Redondo Beach
Joined Oct 2013
Check high performance props of rcg....thread
hubcapsteve is online now Find More Posts by hubcapsteve
Old Jun 30, 2015, 07:00 PM
feefo is online now
feefo's Avatar
Staffs, UK
Joined Apr 2009
My Voodoo was no where near pitch speed BTW
Old Jun 30, 2015, 09:38 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Feefo,
Maybe you can get a longer middle piece so the diameter of the folder increases.
Larger diameter should get you higher % pitch speed.
G.
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jun 30, 2015, 09:50 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Which version it Feefo? Can't remember which one you have - but the latest version works qute well.
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Jul 01, 2015, 05:31 AM
feefo is online now
feefo's Avatar
Staffs, UK
Joined Apr 2009
Not sure which version, I think it's the v3, is that the latest one?
Not sure a bigger yoke is the answer TBH.
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 09:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
