Old Feb 20, 2015, 09:23 PM
FallingFireball is offline
Find More Posts by FallingFireball
Screw plasma flares
FallingFireball's Avatar
Joined Feb 2015
Question
Corrugated-Cardboard Sailplane?
Hello, I want to build a 60 inch (1.5 meter) sailplane from scratch. I am a teenager who doesn't make money very quickly. I once read a book about a genius who builds a spaceship out of cardboard, so I wondered if a sailplane could be built out of such material. What do you all think?
FallingFireball is offline Find More Posts by FallingFireball
Old Feb 21, 2015, 02:12 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
A mockup maybe...
Too soft, too heavy.
renatoa is offline Find More Posts by renatoa
Old Feb 21, 2015, 07:16 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Go to a building site or insulation company - beg / buy broken sheets of foam. That's your cheapest source of materials.
If you can, hot wire cut the foam. If not, with templates for accuracy, carve and sand to shape.
Shedofdread is offline Find More Posts by Shedofdread
Old Feb 21, 2015, 07:53 AM
renatoa is offline
Joined Sep 2007
But first make a budget for RC and electronics
Old Feb 21, 2015, 10:44 AM
buzzfly is offline
Find More Posts by buzzfly
buzzfly's Avatar
Joined Apr 2003
Fireball,
You didn't say what type of flying you intended to do with the plane, which will greatly impact the choice of design and material.
If you're looking for a slope plane, then corrugated plastic is a viable option. Check out the Corobat design here, based on a corrugated plastic wing and plastic baseball bat fuselage.
If you're planing on a thermal plane, then corrugated plastic is (as noted in others' posts) too soft and too heavy.
-- the markster
buzzfly is offline Find More Posts by buzzfly
Old Feb 21, 2015, 10:56 AM
Screw plasma flares
Joined Feb 2015
I'm sorry buzzfly, but I have no idea what a "slope" or "thermal" plane is… ME N00B
Old Feb 21, 2015, 11:00 AM
rockbus is offline
Find More Posts by rockbus
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Does it have to be 60 inch? Here are plans for a 48 inch wing that you probably can scale up:
http://www.rcgroups.com/forums/showt...4&highlight=KF
This plane flies great on the slope. Dont know about flat field. Could mount a pusher motor.
If you have money the Parkzone Ka-8 is on clearance for $99 shipped to your door BNF Spectrum. Thats pretty cheap since it includes 4 servos, 6 ch rxer, flight battery and charger, all you'll need is a Spectrum transmitter.
Good luck.
rockbus is offline Find More Posts by rockbus
Old Feb 21, 2015, 11:09 AM
rdwoebke is online now
Find More Posts by rdwoebke
I'm all about that bass
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
See if you can get some fan fold foam. What part of the world do you live in?
I have been toying with designing a slope plane from pizza box cardboard. Slope flying is if you have a hill/cliff/dune that faces a flat area and has wind blowing to the hill. It creates an updraft you can just fly a glider in indefinitely.
Ryan
rdwoebke is online now Find More Posts by rdwoebke
Old Feb 21, 2015, 11:10 AM
Screw plasma flares
Joined Feb 2015
Thanks ryan - I live in California USA.
Old Feb 21, 2015, 11:23 AM
Screw plasma flares
Joined Feb 2015
I suppose I do not intend to fly slope, but rather at a flying field where I can hand-lauch the plane, take it up to the air with a decent brushless motor, go back and forth between powered flight and gliding, and then belly land it. (Or could I put retracts on it??)
Old Feb 21, 2015, 11:24 AM
rdwoebke's Avatar
Joined Feb 2004
Basically any cliff facing the ocean you can slope soar.
Torrey Pines slope soaring (3 min 27 sec)
This is an example with a high dollar glider but a glider from fan fold or cardboard could fly here too.
Ryan
Old Feb 21, 2015, 11:26 AM
Screw plasma flares
Joined Feb 2015
Also, it wouldn't be completely made of corrugated cardboard and electronics - it would also have spruce spars and styrofoam inside the wing and fuselage, so they retain their shape.
Old Feb 21, 2015, 11:33 AM
Screw plasma flares
Joined Feb 2015
Once again, I have no place to fly slope - but there are 2 nice flying fields that I know of in my area, so I would fly powered to keep the plane into the air and just glide the rest of the time.
Old Feb 21, 2015, 11:43 AM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Then build the KF Flytrap wing I posted a link to and add a brushless motor/ESC and lipo. The BL Motor/ESC and Lipo will cost more than the airframe.
This link is a Flytrap with a motor:
http://www.rcgroups.com/forums/showt...6#post30145313
Forget about landing gear if you build a wing.
The Flytrap wing can be built in an hour once you get all the parts together. You can build the airframe in 1/2 hour or less.
Can you fly RC planes or are you learning?
Old Feb 21, 2015, 12:13 PM
Screw plasma flares
Joined Feb 2015
I can fly a 4-channel quite well, and I do not intend to build a flying wing - just a 60-inch-wingspan powered sailplane with an aspect ratio of 12 - but thank you anyway.
Discussion Could a cardboard glider pack be possible? Fokker Dr. 1 Chit Chat 6 Mar 18, 2015 01:26 AM
Discussion Google Cardboard Big Foot 48 Life, The Universe, and Politics 3 Dec 13, 2014 02:20 PM
Discussion Millenium Falcon-5 feet long out of cardboard dll932 Life, The Universe, and Politics 5 Nov 18, 2014 08:39 AM
Question Source for Corrugated Carbon Fiber Sheets? FoamCrusher Composites Fabrication 2 Jun 14, 2014 06:41 PM
Discussion Pizza Box (corrugated cardboard) Planes? Scratchbuild - It Flies!!! Mujiber Electric Plane Talk 36 Jul 11, 2010 03:17 AM
