Old Jan 20, 2015, 11:13 AM
codys is offline
Find More Posts by codys
codys's Avatar
United States, TX, Sugar Land
Joined Sep 2008
Cool
Pilatus PC-6 Turbo Porter EPO Trainer 1700mm
Has anybody seen this new offering from Hobby King?
Looks interesting to me, I'm digging the drop box on it.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
codys is offline Find More Posts by codys
Old Jan 20, 2015, 12:20 PM
aussie robyn is offline
Find More Posts by aussie robyn
Joined Jan 2012
hi
I have one.
they are well built,
fly very stable,
landing gear fair
ok for the money
regards Robyn
aussie robyn is offline Find More Posts by aussie robyn
Old Jan 29, 2015, 02:11 PM
codys is offline
codys's Avatar
Joined Sep 2008
Have you used the "drop Box" on this plane yet Robyn? I'm curious to see how it is set and functions.???
Old Jan 29, 2015, 08:50 PM
yorkiepap is offline
Find More Posts by yorkiepap
yorkiepap's Avatar
SW PA
Joined Aug 2010
Hey guys,
Yup...the Pilatus Porter is a great looking plane & this HK unit is a really nice size. It's going on my "consider" list. I wish HK would have done a video. I would definitely do some mods on it as I can see some needed improvements.....the landing gear, & the non-retracting "drop box". Looks like they should have incorporated a drop bay similar to that used on the Flyzone Sensei so that opening & closing is servo controlled. I don't believe that this model has the dense foam my 1600mm w/s Dornier DO-27 has since the weight of the Pilatus(1700mm w/s) is 1900g(4.09lb) & my DO-27 weighs 2600g(5.60lb). Still, I may get this one. Pic is my DO-27......
Denny
yorkiepap is offline Find More Posts by yorkiepap
Old Jan 30, 2015, 12:26 PM
Joined Jan 2012
drop box
hi
I have used the dropbox it is spring loaded and released by a servo
when you open the door it lays flat against the fuse behind the holding bay
works ok
regards Robyn
Old Feb 13, 2015, 07:34 AM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Hey guys, here is a video I shot of mine yesterday. I replaced nothing the plastic strut braces with aluminum this morning. Pics to follow.1700MM Pilatus Porter (HK, ArtTech):
1700MM Pilatus Porter (HK, ArtTech) (3 min 34 sec)
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: Carbon Z Cub Floats are here!!
Old Feb 13, 2015, 08:45 AM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Since I did break a strut brace yesterday, I replaced them with aluminum streamlined tubing. I had to put a heat shrink sleeve around each end, as the aluminum I had on hand was smaller than stock plastic. Then it was just a simple drill, and fasten. Looks fantastic.
Old Feb 13, 2015, 04:28 PM
Sperling234 is online now
Find More Posts by Sperling234
Sperling234's Avatar
Los Angeles, Ca.
Joined Jun 2010
Hey! Great to see that model in the air. Thanks for posting it.
I'm curious as to which 13x5 3 blade you used. It seems to power it just fine and adds that very nice scale look.
Looks great!
Cheers,
Scott
Sperling234 is online now Find More Posts by Sperling234
Latest blog entry: Raiders Wing from Scratch
Old Feb 13, 2015, 06:22 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
I used the motor and prop combo from the FMS Edge 540. Parts are available under the spares tab for that plane, at motionrc.com.
I had to cut about 1/2" of foam off the front end to mount the FMS motor further back than stock. I also trimmed the cowl (slowly using a grinder/dremel) until my spinner gap was where I wanted it. I flew the plane stock for 3 flights, then did the power swap. Stock power is adequate, but I wanted more. I don't have unlimited vertical, but close. I will be fitting floats, and the extra power will come in handy.
-CC
Old Feb 14, 2015, 04:40 PM
yorkiepap's Avatar
SW PA
Joined Aug 2010
Hey Cc,
I see you also broke one of the rather cheap LG struts as I have read others have. When I get mine, I'll make a new set out of alum. tubing so they are spring-loaded telescoping like the scale plane. I managed to download some very nice close-up pics of the underside of the fuse & the entire LG strut assem.. I'll be sure to post detailed pics.....
Denny
Old Feb 14, 2015, 06:37 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
I think I am going to run some Kavan air-filled tires for land ops. I have the floats in hand, but have not had a chance to tinker with installing them.
Old Feb 15, 2015, 02:43 PM
codys is offline
codys's Avatar
Joined Sep 2008
Thanks CubCrazy for posting your experience with this PC-6!!!!
Old Feb 20, 2015, 09:59 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
New Kavan 5 inch balloon tires came today. Ordered from SIGMFG.COM I will paint the hubs flat black.Kavan makes the lightest air filled tires in the industry. I had 4 inch on my old Flyzone Beaver. They are awesome. Second pic shows them next to the 3.5 inch Dubro low bounce I was running. Now it is a true bush plane.
Their site is a little odd to deal with, but I got my wheels in about 3 days, and shipping was $3.95
Old Feb 20, 2015, 10:18 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Flew the PC6 on the old tires 2 days ago. I wish I could capture the sound this power setup makes. It has a really neat woosh that makes it seem more like a Turbo-prop. I think the exhaust pipes create a sound when the air passes by. I am LOVING this airplane. PERFECT replacement for my Flyzone Beaver that I sold in the fall.
-CC
Old Feb 20, 2015, 10:27 PM
yorkiepap's Avatar
SW PA
Joined Aug 2010
Hey Cc,
I'm ready to order one. The posts from you & Porcia83 over at RCUniverse & the HK site, under plane discussion, kinda sealed the commitment to buy one. I'll be contributing to this thread when mine arrives & the build w/any mods I may do. I definitely WILL add the larger tires as you have done. Thanks....
Denny
Discussion Flitework Pilatus PC-6 Turbo Porter EricClark Giant Electric Planes 333 Today 11:14 PM
Build Log Pilatus PC-6 Porter 40 The World Models Kit bettsmums Scale Kit/Scratch Built 24 Apr 16, 2015 04:59 PM
Build Log Pilatus PC-6 Porter 61rcpilot Scale Kit/Scratch Built 6 Dec 15, 2014 11:39 AM
Build Log Pat Tritle Pilatus PC-6 Porter 60'' Build mstukel16 Scale Kit/Scratch Built 11 Nov 18, 2014 11:51 PM
Build Log 80" Pilatus PC-6 Turbo Porter MRAerodesign robertus Giant Electric Planes 7 Jul 16, 2014 11:28 AM
