Old Dec 15, 2014, 01:30 PM
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Originally Posted by Snakebite666 View Post
Well I'm assuming the rear gear isn't supporting HUGE amounts of weight...
But if it's just skin, yeah, some sort of support inside would be good, don't wanna grab the tail to turn it and push the struts thru the skin!!!
YES It's not the weight it's if you were to roll it and it was to catch on something the gear would come loose fairly easy; I feel better w/ something locked in.
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Dec 15, 2014, 06:34 PM
Baltimore MD USA
Joined Jan 2011
I had to glue in some 3/8" dowels w/ holes drilled in them to give the front struts some BEEF
It's only 1/8" balsa skin back there; I glued them in w/ Gorilla glue after wetting the dowels.
I had brass inserts w/ plates but I didn't need those, the 3/8 poplar dowels are fine for this.
I also did some work on the tail feathers I installed a removable hing for the top of the rudder.
And I also fit and drilled in a brass insert for my fiberglass tail piece counter sunk and screwed it on.
I finished the aft beaching gear and panted it, I like these wheels better than the front ones and maybe ordering 4 solid rubber ones for the front; they are getting flat.
They must not be rated for a plane this size .
Check it,
Old Today, 02:49 PM
Baltimore MD USA
Joined Jan 2011
HERE'S WHAT I'M DOING I COLOR CODE THE PLUG ENDS.
THE WING BOLT WILL PULL THE CONNECTORS TOGETHER.
THAT PART IS EASY: REMEMBERING WHAT THE
I DID A YEAR AGO IS THE PROBLEM. LOL
Bruce
Build Log 8' WS PBY-5 Vintage Plans Robert Sweitzer splinterz25 Fuel Warbirds 1586 Today 06:09 PM
For Sale NIB Aerodrome RC 55 5/8 Fokker D7 Short Kit/Plans centex pilot Aircraft - Electric - Airplanes (FS/W) 4 Dec 24, 2013 09:22 PM
Sold Vintage RC Plans 108" PBY 5-A with plastic parts AVGDAY Aircraft - Electric - Airplanes (FS/W) 0 Jan 29, 2013 11:08 AM
Sold Vintage RC Plans 108" PBY 5-A plans and plastic AVGDAY Aircraft - Fuel - Airplanes (FS/W) 0 Jan 29, 2013 10:59 AM
For Sale 1/4 Scale Robert Star Bumble Bee Plans & Foam Wing Cores M.Putnam Aircraft - Fuel - Airplanes (FS/W) 0 Jan 02, 2013 10:16 AM
