Old Dec 15, 2013, 10:44 AM
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
Build Log
christen eagle
christen eagle new project
just starting to gather all the info that we will need to get up and running
full size info need a model of scale to fit 45cc to 175cc gas motor
Operational history Christen Eagle II
In 1979, the Eagles Aerobatic Team (Charlie Hillard, Tom Poberezny, and Gene Soucy) chose the Christen Eagle as a replacement for their Pitts Special airshow act "The Red Devils". The act continued until 1995. All three Christen Eagles hang from the lobby of the EAA Airventure Museum in Oshkosh, Wisconsin.[2]
Specifications General characteristics
Crew: One pilot
Capacity: 1 passenger
Length: 5.46 m
Wingspan: 6.07 m
Height: 1.98 m
Wing area: 11.6 m2
Empty weight: 465 kg
Gross weight: 716 kg
Powerplant: 1 × Lycoming AEIO-360-A1D, 200 hp (149 kW)
Performance
Maximum speed: 184 mph (296 km/h)
Range: 380 miles (610 km)
Service ceiling: 17,000 ft (5,180 m)
Rate of climb: 2,100 ft/min (11 m/s)
info so far
SPECIFICATIONS
Wingspan: Top: 1740 mm Bottom: 1640 mm
Wing Area: 92.6 dm˛
Weight: 6800-8160 g
Wing Loading: 79-88 g/dm˛
Length: 1585 mm
Requires:32-52 cc) gasoline engine & 4-channel radio w/8-9 servos.
dpot is offline Find More Posts by dpot
Old Dec 15, 2013, 02:30 PM
Joined Jan 2009
Last year I framed up the 50% scale Classic Modelbau Kit for a customer who buillds and flies/operates several several full scale Eagles. Major disappointment in scale fidelity, ease of construction, etc. POOR engineering and building practices throughout. Poorer construction notes and an even poorer German to English translation. Engine is 19 hp. flat four Desert Aircrft type.
I see a disturbing scale error on your drawing,which also plagues the Modelbau effort. The lower wing chord is not the same as upper, being some150mm shorter and proportionally thinner, in section.
I have access to all Eagle construction drawings and hope to render truly accurate scale drawings one day. If I live long enough, that is
packardpursuit is offline Find More Posts by packardpursuit
Old Dec 15, 2013, 09:12 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
Frank Knoll 38% Christen Eagle $55
I was given the info from another here on RCG, he gave me the name, "Rick Boyer"
it what I came up with when looking for a 50cc CE
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: heli's
Old Dec 16, 2013, 03:46 AM
dpot's Avatar
Joined Dec 2005
all i have found is this but still looking i have sum plans on a Ao sheet and plans from hear http://www.hippocketaeronautics.com/....php?cat_id=72
but would like to have a look at the full size layouts
Old Dec 17, 2013, 02:29 PM
dpot's Avatar
Joined Dec 2005
got most of fuz drawings fineshed work on wing to knight start lower wing tomorrow knight
Old Dec 17, 2013, 06:55 PM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
The Rick Boyer plans are the Andy Sheber Design, for the Pitts S-1 and S-2, in 1/3 and 1/4 scale. (unless he has Eagle plans I'm unaware of)
You can make an Acceptable stand-off scale Eagle with parts from Fiberglass Specialties (Cowl,Wheel Pants, and Canopy) and some reshaping of the flying surfaces..The interplane struts are different,as is the landing gear.
All the Eagle colors are available from F&M Stits , among other suppliers, if you're going with the aerobatic team's scheme.
I watched the Eagles Aerobatic Team in Latrobe Pennsylvania, many years ago.I wanted to get close-up pictures,and Tom said I'd have to "crew" for them in order to get on the tarmac...I held a bucket and a rag, while we pushed the aircraft to the staging area.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: Back to square one !
Old Dec 18, 2013, 08:22 AM
dpot's Avatar
Joined Dec 2005
new up date on fuz extended the fin set motor box so it will slide forward and back to help with placement of the motor
Old Dec 18, 2013, 04:52 PM
Joined Feb 2008
[QUOTE=epoxyearl;26929778]The Rick Boyer plans are the Andy Sheber Design, for the Pitts S-1 and S-2, in 1/3 and 1/4 scale. (unless he has Eagle plans I'm unaware of)
Rick Boyer has the Frank Knoll Eagle plans. They were $55 when I last communicated with him a couple of years ago.
GeneH
Alpha35 is offline Find More Posts by Alpha35
Old Dec 19, 2013, 03:00 AM
dpot's Avatar
Joined Dec 2005
thanks for info Rick Boyer Frank Knoll Eagle plan have search on internet and come up with 000000
i am a grate believer in taking what is already there and improving it this is the only plan that i have come up with http://www.hippocketaeronautics.com/....php?cat_id=72
and if is FREE although the form of construction needs updating (OK you balsa builders it is a good way of building)
and there is plenty info combined with the 3 view drawing for me to put it on computer for cnc short kit cutting
Old Dec 19, 2013, 06:40 AM
epoxyearl's Avatar
Joined Oct 2011
I have Rick's E-mail addy, but I won't post it here..
I sent you a PM...His Pitts plans, from the original Andy Sheber ones show the S-2 at 80" upper wing span.
as previously stated, it makes a reasonable facsimile.
Old Dec 19, 2013, 01:45 PM
dpot's Avatar
Joined Dec 2005
finished the part layouts and started cowl and spats drawings plug for cowl
Old Dec 19, 2013, 03:30 PM
Joined Feb 2008
You might want to checkout page 5 of this thread:
http://www.rcuniverse.com/forum/gian...eagle-i-5.html
RE: 38% Christen Eagle I
Hi guys,
I just got another order for Christen Eagle fiberglass cowls and wheelpants in last week and I still have the drawings and parts for the Frank Knoll 38% Christen Eagle and Andy Sheber Pitts Special in 1/4, and 1/3 scale (Both the S-1S and S-2A). I competed with two modified Sheber Pitts Special S-1S's at Top Gun for several years and I'm working on a 40% Sean Tucker Challenger II for TG.
Rick Boyer
Old Dec 20, 2013, 02:00 AM
dpot's Avatar
Joined Dec 2005
Hi guys,
Rick Boyer
how much for the cowl spats and plan $$$ do you offer cnc cut parts
Old Dec 20, 2013, 02:18 PM
dpot's Avatar
Joined Dec 2005
work on cowl
Old Dec 25, 2013, 10:25 AM
dpot's Avatar
Joined Dec 2005
cnc cut files for video cowl
christian eagle cowl (3 min 56 sec)
For Sale Hangar 9 CHRISTEN EAGLE II ARF/RTF/BNF/LPU ZRX212 Aircraft - Electric - Airplanes (FS/W) 0 Nov 26, 2013 05:28 AM
For Sale Hangar 9 CHRISTEN EAGLE II ARF/RTF/BNF/LPU ZRX212 Aircraft - Electric - Airplanes (FS/W) 0 Nov 22, 2013 12:06 PM
Sold Great Planes Christen Eagle 42.5" $225.00 Local Pick Up Only Mark Flyer Aircraft - Electric - Airplanes (FS/W) 2 Nov 21, 2013 03:32 PM
Sold GP Christen Eagle ..45 - .60 SOLD koppterX Aircraft - Fuel - Airplanes (FS/W) 3 Nov 21, 2013 02:38 PM
For Sale Hangar 9 CHRISTEN EAGLE II ARF/RTF/BNF/LPU ZRX212 Aircraft - Electric - Airplanes (FS/W) 2 Nov 20, 2013 11:45 AM
