Old Aug 17, 2014, 09:21 AM
United States, MO, Stockton
Joined Oct 2013
Question
20 cc engine
I'm currently trying to put an electronic ignition, on a 20 cc engine. yeah its a weed wacker engine, but i had it rigged with a prop and it really screamed, the problem was the engine housing couldn't be taken off due to the old ignition system. I bought a timing wheel and the ignition kit, but the instructions are very bad, and I've never attempted this before, the wheel has no markings for what tdc is but i do know the hall sensor is to be put at 25 degrees. is there a thread or a how to do this modification thanks for any input sam
slam555 is offline Find More Posts by slam555
Old Aug 17, 2014, 05:06 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
This instruction page May help you.
http://www.rcextremepower.net/ignition_timing.html
Hope it helps.
Fokker DII is offline Find More Posts by Fokker DII
Old Aug 17, 2014, 07:21 PM
Joined Oct 2013
20cc
thats pretty much what I'm doing, the marks end up on the bottom side of the engine I guess it doesn't matter where the sensor is so long as the magnet passes at the 28 degree mark thanks sam
Old Aug 17, 2014, 07:41 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
You are right, the engine doesn't care where the hall sensor is located as long as the timing is right. 28/30 deg. is most normal.
Old Aug 18, 2014, 07:18 AM
Joined Oct 2013
20cc
thanks for the info, if this works well, my stearman is next
Old Aug 18, 2014, 12:58 PM
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
you don't have to mount the sensor where the marks are....just make sure that the trailing edge of the magnet is inline with the trailing edge of the sensor (magnet just leaving the sensor) when your 28 deg. BTDC marks are aligned.
take into account that the sensor housing/mount is a bit wider than the sensor itself so adjust for that.
ZAGNUT is online now Find More Posts by ZAGNUT
Sold New DLE 20 cc Gas engine frankle951 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 11, 2012 09:06 PM
Wanted 20-30 cc gas engine hobbiconexstar Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 21, 2012 08:32 PM
Sold NEW Item-35 CC Gas Engine the same size as a .91-1.20 Glow Engine!!! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 8 Apr 17, 2012 11:23 AM
Wanted 20 to 35 cc engine dpenoncello Aircraft - Fuel - Engines and Accessories (FS/W) 3 Mar 12, 2012 11:01 PM
