Old Yesterday, 12:38 AM
Stringer is online now
Find More Posts by Stringer
Stringer's Avatar
Joined May 2013
Originally Posted by alexraz View Post
I see. If frequency hoping would help, I might even consider OrangeRX UHF LRS. it does hoping on specified frequencies. They can just avoid the frequency they use on the radio.
I would need a separate channel for the gimbal controller. I don't know if that's possible with PPM to the FC.
I wouldn't trust the OrangeRx one. I had a set two years back and the range was really bad. If you choose OpenLRS, at least get the DTF UHF/HawkEye hardware. Since you will be using PPM to the FC, you should have enough extra ports on the Rx to control the gimbal.
Stringer is online now Find More Posts by Stringer
Old Yesterday, 04:33 AM
alexraz is offline
Find More Posts by alexraz
Philippines, NCR, QC
Joined Apr 2014
I'm using Orange RX now. Pretty decent. Haven't maxed out the range with a home made turnstile and a diamond 433mhz Tx antenna. I've even FPVed from inside the house using a 40" tv hehehe. I'll test out what I have in the conditions the team needs them for. It's good to have options.
Thanks on the ports tip. I'll figure it out with the equipment I have now.
alexraz is offline Find More Posts by alexraz
Discussion RC flying in the Philippines neoradix 3D Fuel Heli Flying 22 Dec 20, 2014 07:54 PM
Discussion Philippine Aerial Photos mykmaspogi Aerial Photography 16 Aug 18, 2012 01:06 PM
Discussion Our Flying Field (Philippines) mykmaspogi Your Plane Photos 3 Aug 20, 2008 03:28 PM
Question RC Frequency Band in the philippines athrun4211 Radios 1 Apr 21, 2008 10:47 AM
Flying field in Manila, Philippines??? Any one? Butch777 Electric Plane Talk 2 Sep 26, 2004 08:14 AM
