Old Dec 08, 2014, 09:57 PM
Get your build on!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
Mini JW - Builds, Mods, Tips and Tricks
The new and improved Mini JW is a sexy little beast. With the revised airfoil and profile comes the need to update build techniques and tricks. Please share your build and eureka moments of the Mini JW!
Aerogance is offline Find More Posts by Aerogance
Old Dec 08, 2014, 10:43 PM
Get your build on!
Aerogance's Avatar
Joined Sep 2008
Aaron's mere mortal build
I have been working on my Mini JW within the small windows of free time I have had lately. I wanted to shoot for a mid-weight build so I opted to put the battery in the wing. My radio gear is as follows:
RX: Spektrum AR400
Battery: Custom Eneloop AAA 4-Cell "2x2" flat pack
Servos: Hitec 82MG
Notes: the RX is tiny but the top plug configuration required mounting the RX on its side to fit in the wing. The 82MGs are fairly thick but fit. One size down in thickness 10mm -> 9mm would help.
Old Dec 14, 2014, 04:41 PM
Get your build on!
Aerogance's Avatar
Joined Sep 2008
Wing is gooped and spackled. Should be finished this week.
I have never been 100% satisfied with the smoothness of my wing tips. This time I smeared white Gorilla glue on the sanded EPP tips and let it cure without spraying with water. Foaming was only 1/16". I then gently sanded the tip back to shape. After the goop and spackled process the tips were very smooth. I will do this process from now on and will also used it on my fuselages.
Old Dec 17, 2014, 01:05 AM
Get your build on!
Aerogance's Avatar
Joined Sep 2008
Mine is almost finished. Wing is covered in 10 mil D.I. with digital skins. Using the coroplast tail, she weighs 20oz before linkages and nose weight. I expect her to land between 25 and 30 oz AUW. The 10 mil added a lot of weight. So did having the battery in the wing, the large servos and massive power switch.
Old Dec 17, 2014, 01:31 AM
PB of 733kph
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
Should be a contender for 200. Looks great
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Dec 17, 2014, 12:42 PM
Confirmed Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
Dang, another great looking JW. Wow.
screamin' eagle is offline Find More Posts by screamin' eagle
Discussion JW 36 (The Mini JW) Aerogance Dynamic Soaring 22 Yesterday 06:23 AM
Discussion NEW Losi LST XXL 2 Unboxing, Break In, Tuning, Tips and Tricks All Here makuloco2000 Off-road Cars 8 Dec 16, 2014 01:56 PM
Discussion Tips, hints and tricks Dennis99 Dock Talk 10 Oct 12, 2014 11:25 AM
Discussion The Hubsan X4 H107C Tips and Tricks for best video! iKokomo Mini Multirotors 0 Oct 10, 2014 05:09 PM
Discussion Getting caught up with JW's! and some tips/tricks KingOfTheHill Slope 27 Dec 27, 2007 08:16 PM
