Old Oct 25, 2014, 06:28 PM
Greenville, SC
Joined Jul 2007
Sailaire with flaps
I couldn't find the other threads where I had seen this subject mentioned so here's a new one. I recall that there were yea's and nay's on the subject but no comments from anyone having actually flown a Sailaire with flaps.
So I had to re-cover my 25+ yr old Pig and decided to change from spoilers to flaps in the process. The spoilers were not allowing me to de-thermal from spec altitude as quickly as I would like and I was very curious as to how effective flaps would be for landings. It was a simple re-do; I cut in 2 1/2" from the TE, then took 1/4" off the front of the flap ribs/caps. The main panels then got a 1/8" strip as a sub-trailing edge and the same was added as a face to the flap pieces. Resulting flap width of 2 1/4" is probably as much as one would want to go, given the ground clearance.
Test flights were today and WOW! I must say they exceeded my expectations. First flight was about 7 or 8 min, not a lot of altitude, so I waited until I was down to about 40 or 50 feet for the initial test. I lined up into a stiff breeze (est. 10-12) and pulled the lever. The 2 or 3 degrees of down elevator mix was perfect. That big 'ol beast just slowed to a crawl and stayed steady as a rock. An instant before touchdown I ballooned it and dumped the flaps and it just literally sat straight down in the grass with nearly no forward movement. Couple of launches later, I popped off into a monster thermal and let it get some altitude to check the flaps for quick descent. I was able to add in some down stick with no apparent over-speed. I also had one landing in a dead calm and the total 'skid-out' was not much more than 18 or 20 inches. Quite a change from the 6 to 10 feet the Pig is capable of.
The only casualty was a loose flap horn on the right side due to an inadequate glue job. I knew there would be some stress on the linkage if the flaps didn't get retracted soon enough on landing and thought I had put enough strength under the horn but just screwed up the glue job. If you have been thinking about adding flaps to a Sailaire but couldn't decide if it would be worth the effort, I can now tell you from experience that it is. Just make sure you use enough glue.....
mocgp is offline Find More Posts by mocgp
Old Oct 26, 2014, 04:47 PM
United States, MA, Waltham
Joined Dec 2001
Have you tried the flaps and spoilers together?
If you come in slower than normal with flaps, you won't be able to stretch your glide by retracting them. If you keep the speed up, you can still do this. Probably doesn't matter much if you don't mind landing short and it's not gusty.
I've only flown a Sailaire with spoilers, and not for very long. I liked it, though.
lincoln is offline Find More Posts by lincoln
Old Oct 26, 2014, 06:34 PM
Greenville, SC
Joined Jul 2007
For this mod, I removed the spoilers. The mechanism was old and didn't work all that great. I'm also flying at at sod farm so I don't have issues with where it ends up.
Old Oct 26, 2014, 08:28 PM
R.M. Gellart's Avatar
Joined Nov 2005
Had a gentleman from Ohio that flew a Pig wth flaps for a numbers of years. He made them pretty big and they were pretty effective. Not that it made much of a difference in thermals, but it was a different way of doing things and it was better in the landing circle. Sad part, he could not fly it in RES or Nostalgia.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Oct 26, 2014, 09:34 PM
fa2
Joined Jan 2010
my pig was so slow that landing was never a problem - spoilers were fine for me - my buddies used to call my pig "old flat bottom"
fa2 is offline Find More Posts by fa2
Sold BNF Great Planes Cherokee with flaps pdansalvish Aircraft - Electric - Airplanes (FS/W) 0 Sep 25, 2014 04:13 PM
For Sale Free LPU Speedo with flaps, mild damage cityevader Aircraft - Sailplanes (FS/W) 8 Sep 25, 2014 01:46 PM
Wanted Wings only 3-3.5 m with spoilers or flaps WallsRoofing71 Aircraft - Sailplanes (FS/W) 1 Sep 24, 2014 10:30 PM
Discussion DX8 flap setup Funcub with 1 aileron and 2 flap channels ham Electric Plane Talk 3 Aug 15, 2014 06:44 AM
Sold Dream Catcher Sailaire NIB with servos $300 shipped USPS ground CONUS be69ar Aircraft - Sailplanes (FS/W) 1 Jan 07, 2014 12:01 PM
