Old May 29, 2016, 04:48 PM
Spark1815 is offline
Find More Posts by Spark1815
United States, WA, Pullman
Joined May 2016
Inherited a GWS Slowstick - need help
I recently had a neighbor move away and as he left he handed me his GWS Slowstick and some parts.
Included in the box of supplies is an Electrify SS-25 Brushless ESC, E-Flite Park 370 Outrunner 1360KV motor and a ThunderPower LiPo 1320mah/7.4V 2 cell battery.
I already have a Futaba 6EXAP - 6 channel Tx, PCM1024 - R146iP Rx and S3114 servos.
I have everything installed, but cannot get the motor to function correctly. The servos are working fine but when I engage the throttle the motor will come on but it is very choppy and only one speed, very slow. Increasing throttle has not effect. Throttling back to off will turn it off though. At 3/4 throttle it will continue with the choppy behavior for about 5-8 seconds and then stop.
The battery is charged to 8.4V but appeared to stop at approx 780mah. The charged stopped after 67 minutes.
Any ideas? I have read all of the documentation I can find for each of the pieces in the puzzle but no success on a solution.
Thank You for any help.
Spark1815 is offline Find More Posts by Spark1815
Old May 29, 2016, 05:38 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
It sounds like you have a bad connection between the ESC and motor in at least one of the 3 wires. Double check everything and try again.
Steve
slipstick is offline Find More Posts by slipstick
Old May 29, 2016, 06:33 PM
Joined May 2016
Checked all connections again and after closer inspection of motor it appears there are tow or three discolored coils. Also, tried to operate again, same result but a little smoke escaped the motor. I am thinking I might need to try a new motor.
Old May 30, 2016, 12:26 AM
JureZ is online now
Find More Posts by JureZ
Sokol
JureZ's Avatar
United States, CA, Walnut Creek
Joined Jul 2013
this is the replacement motor page (expensive)
http://www.horizonhobby.com/park-370...360kv-eflm1205
Key Features
  • Great upgrade for Speed 280 and Speed 370 applications
  • Excellent motor for small 3D airplanes weighing 7–14 oz (200–400 g)
  • Extremely lightweight—just 1.6 ounces
  • Ideal for models requiring up to 150 W
  • requires 10–20A brushless ESC
8x3.8 to 10x4.7 prop
11.1V to 7.4V – 480 to 1320 mAh Li-Po
JureZ is online now Find More Posts by JureZ
Old May 30, 2016, 12:52 AM
JureZ is online now
Sokol
JureZ's Avatar
Joined Jul 2013
brushless motor for GWS SS : http://www.rcgroups.com/forums/showthread.php?t=2200508
check this thread for general info and motor suggestions : http://www.rcgroups.com/forums/showthread.php?t=407136
Old May 30, 2016, 02:05 AM
Joined May 2016
Thank you for all the info and links. This should give me lots of ideas.
-Chris
Sold GWS SlowStick Power System NEW, w/propellor FourDollaRacing Aircraft - Electric - Power Systems (FS/W) 3 Feb 11, 2016 05:09 PM
Sold GWS Slowstick + motor +ESC rice rocket Aircraft - Electric - Airplanes (FS/W) 4 Jan 19, 2016 08:40 PM
Discussion GWS-SLOWSTICK - need help completing parts order The Raddish Beginner Training Area (Aircraft-Electric) 6 May 28, 2008 09:43 PM
Sold Ready to fly GWS slowstick! radio, batteries, charger. everything you need... dacaur Aircraft - Electric - Airplanes (FS/W) 3 Dec 04, 2006 01:11 AM
GWS slowstick.....Help please Code 33 Beginner Training Area (Aircraft-Electric) 10 Dec 20, 2003 04:40 PM
