Old Jan 12, 2016, 12:30 PM
JGAF is offline
Find More Posts by JGAF
Aerobatics!
JGAF's Avatar
United States, CA, Oceanside
Joined Nov 2007
Keeping up with the 4D'ers
RJ Gritter 3D Freestyle Flying at E-Fest 2015 (4 min 2 sec)
So I'd like to make a glider do what this plane does at 2:30 or so, only instead of using a reversible pitch propeller I'd like to use giant ailerons and massive vertical slope lift (Fermin)
My first thought would be to use a wingeron setup but I'm not sure how I could get enough throw on the wings to achieve the auto-rotation effect that I'd like. The other option is to use massive counterbalances on the wings, however there are obvious disadvantages here in normal gliding flight. Maybe drooperons?
I'm going to build a plane to achieve this soon, but I just wanted to put my thoughts out there to see if you guys can come up with any suggestions
JGAF is offline Find More Posts by JGAF
Old Jan 12, 2016, 01:08 PM
wolfv is offline
Find More Posts by wolfv
wolfv's Avatar
Las Cruces, NM
Joined May 2007
Do you mean transform between fixed-wing and rotary-wing in mid flight?
Like these:
http://science.dodlive.mil/2013/02/1...g-transformer/
http://www.gizmag.com/hybrid-rotorwi...p-rotor/27092/
https://en.wikipedia.org/wiki/Boeing_X-50_Dragonfly
wolfv is offline Find More Posts by wolfv
Old Jan 12, 2016, 01:14 PM
JGAF is offline
Aerobatics!
JGAF's Avatar
Joined Nov 2007
I mean counter-rotating the wings or ailerons to produce enough roll to slow the descent when the plane is pointed straight down.
Old Jan 12, 2016, 01:24 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
"4D"? Is that what a 3D plane becomes when it reaches 88 miles an hour and gets hit by lightning?
Fly Wheel is offline Find More Posts by Fly Wheel
Old Jan 12, 2016, 01:48 PM
Mr. Combat Certain is offline
Find More Posts by Mr. Combat Certain
EPP Extrordinare
Mr. Combat Certain's Avatar
United States, CA, San Clemente
Joined Feb 2008
I think the difference is that a glider relies on momentum to throw itself into maneuvers via gravity to gain speed, whereas the electric plane uses the prop to provide momentum, in this case it does it in both directions. Another issue is this is indoor with no wind, which makes it easier to balance the plane on its tail/nose. With wind blowing both into and up the slope it will be hard to keep it in one spot. You'd almost have to have the wings pivot enough so it auto-rotates with the fuse vertical, like this little helicopter https://www.bing.com/images/search?q...2o0&ajaxhist=0 Probably not impossible but itll take some thinking ...
Mr. Combat Certain is offline Find More Posts by Mr. Combat Certain
Old Jan 12, 2016, 01:58 PM
wolfv is offline
wolfv's Avatar
Las Cruces, NM
Joined May 2007
Here is one way to counter-rotate left and right wings about the spar.
Similar to two-piece wing with a spar joiner, and the wing's angles of incidents counter-rotate about the joiner.
Rotating tube spars:
One fixed round tube spar glued to fuselage.
Rotating tube spar glued to inside of each wing (symmetric airfoil).
The fixed tube spar is nested inside left and right rotating tube spars.
One servo rotates a wing up 80 degrees, and another servo rotates the other wing down 80 degrees.
Maybe nylon bushings glued to the fixed spar.
Pins to keep the rotating tubes from sliding off the fixed tube spar.
In a dive, transitioning between fixed-wing and rotating-wing is straight forward.
Another idea:
Add lead weights to the wing tips for additional inertia.
Get the glider spinning fast in a vertical dive, then give the wings 100 degrees pitch, like the collective pitch on a helicopter.
With enough energy stored in the inertia, the glider could go up tail first, with only gyroscopic effect keeping the tail pointing straight up.
I don't know it that would actually work, but it looks cool in my head.
Instead of lead weights, could put servos or batteries in the wing tips.
Last edited by wolfv; Jan 13, 2016 at 11:20 AM. Reason: Added lead to the wing tips
Old Jan 12, 2016, 06:25 PM
JGAF is offline
Aerobatics!
JGAF's Avatar
Joined Nov 2007
The Lightning was just a power source for the flux capacitor because they didn't have anything else capable of producing 1.21 jigawats
Good ideas so far wolf, keep them coming !
The only way I can think of pulling it off Jordan would be to build the plane as light as possible & fly where there's a lot of vertical lift & not much blow-back like Fermin in 5-15 mph
Old Jan 12, 2016, 06:55 PM
dawsonh is offline
Find More Posts by dawsonh
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
Justin:
I think you have it figured out.
Big ailerons with huge throw.
A light build
A vertical lift site.
You can do it!
As you know, I have been able to do hovering flat spins and flips with Le Fish light and Buzz Evo at Mormon Lake Overlook. A hovering down line roll should be possible. Maybe a split rudder (to add drag) would help. Or maybe a two servo elevator setup, so you could add additional roll input (taileron?)
Dawson
dawsonh is offline Find More Posts by dawsonh
Old Jan 13, 2016, 10:30 AM
kbstingwing is offline
Find More Posts by kbstingwing
FLY OR DIE YOU MAGGOT
kbstingwing's Avatar
Vista, Ca
Joined Oct 2002
Make a split wing, with dual aileron servos on each side, use dual servos to split the wing and retract, (cheap micro servos), it would be a full size air brake. or you could do split wing tips.
kbstingwing is offline Find More Posts by kbstingwing
Old Jan 14, 2016, 07:19 AM
gazasmith is offline
Find More Posts by gazasmith
Rock Breaker
gazasmith's Avatar
Australia, QLD
Joined Jan 2013
I have a wicked wing I can almost hover nose down. It's about 600g so only good in stronger breezes. A light build would work better. I have big control surfaces split top and bottom, open for air brakes or they work together as ailerons elevators. Awesome for pilot combat as you can slow it down fast.
gazasmith is offline Find More Posts by gazasmith
Old Jan 14, 2016, 07:33 AM
Rock Breaker
gazasmith's Avatar
Australia, QLD
Joined Jan 2013
This is my evo version. I cut 30mm off tha back of the wing then have 100mm control surface at wing tip. The balsa control surfaces are not stiff enough I need to make carbon ones. you need good hinges other wise it's to hard to keep trailing edge together to limit drag.
Old Jan 14, 2016, 03:24 PM
Vista, Ca
Joined Oct 2002
yes, Something similar to this, but the entire wing is the air brake.
Discussion Wiring up a big Nimbus 4D? LRFitch Scale Sailplanes 7 Sep 02, 2015 09:46 AM
Question Naze32 keep beeping with VBAT set up DPadula Multirotor Talk 4 Aug 31, 2015 04:21 AM
Discussion Bay Area California Fpv'ers Los'ers Post Up bayareaheli Mini Multirotors 17 Nov 10, 2014 09:52 PM
4D'ers, Need your input...... rc-eflyer 3D Flying 3 Jul 30, 2005 11:19 PM
